The bass pot value simply determines the maximum amount of bass.
What are the other tone stack values (caps/resistors)?
Is it Cathode or Anode follower?
Is there a Volume control immediately after the treble pot?
What is the PI configuration and operating conditions?
What voltage swing do you require to drive the 12AU7 PP OP stage?
Lots to think about
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
So no phase inverter
I hope the pic below will help...
Just for one potential difference - bear in mind that the full-size amp uses negative feedback from the output to the phase inverter... if you omit or alter that, it will change the sound significantly.
But from what I know the 100k mid pot was used earlier and the 250k pot came later - possibly with the skyline mod.
ICBM is right in that you need the negative feedback to smooth things out. I was always of the impression that a part of the Dumble sound was the high headroom power amp.
You can use a different power section easily, but once built you will probably have to tweak things to make it all work the way you expect. That's part of the fun of it.
In short, different circuit, means there isn't necessarily an equivalence in the values of components.
Bare in mind as others have said, the Dumble ethos is a powerful clean power amp and they are complex builds too. You risk putting in a great deal of time and effort into building something that never sounds like you want it to because you've messed with the recipe.
For example, would being single ended get away from what makes a Dumble sound like a Dumble.
A push pull 20 watt Dumble might be a compromise with 2x 6v6s for home/low volume use... or even a 12au7 set up in push pull? Just ideas... be interested to see how it works out.
https://robrobinette.com/5e3_Modifications.htm#Other_5E3_Modifications
And his Deluxe Micro 1 watt
https://robrobinette.com/Deluxe_Micro.htm
Get you close? It may depend which Dumble you had in mind, ofc.
…that is exactly what I had in mind
Except that rather than the Tweedledee, I’m going to go for a ‘proper’ front end of a Dumble overdrive special #124
...which is 76% of the volume of a 50W job...
