WSA (Wanting some advice!)
I have recently moved back to a Helix and wanting to power it at home rather than always using headphones.
Mono is fine and have no space for powered stereo speakers anyway.
GRGuitars powered amp: Had a Redsound powered amp for a Kemper about four years ago which was great sounding. They now appear to be sold as GRGuitars, made in Italy and back control panel looks identical to the Redsound I had.
Any thoughts? other options?
Line 6 Powercab - physically big, and sound?
Seymour D. power stage amp and Zilla Cab? - noisy fan?
Ta Jon
Helix -> SD Powerstage -> Guitar cab is exactly how I ran mine, both at home and gigging, and it sounded excellent no matter where I was. Best rig I've ever had.
I've since reverted to 'real' amps again, but I've kept the TC3 just in case I ever go back to this type of rig.
I see they've now released a very neat version that could easily be integrated under a pedalboard, or even into a cab directly. That said, I'd rather not send monies to russian companies right now so I would look for used ones if this appealed to you (your politics may vary!)
I'm still using the Zilla with other amps, it's loaded with a Celestion G12H Creamback and covers a lot of ground - highly recommended.
Sounds great.
I’ve been using a Laney LFR112 which I also use for gigging. Not exactly compact but sounds pretty good. Also been considering the DV Mark Powered cab, mainly as it’s quite a bit lighter than the Laney.
I use my Helix at home (both the Rack and Helix Native embedded in Logic) through my desktop monitors, which are Genelec 8040Bs.
Live, I use it through the PA with a HK Audio LINEAR 5 112 XA for monitoring. I sometimes bring one home if I want to dial in sounds, or be loud!
R.
Eqd Speaker Cranker clone
