I have a very simple rig....Tuner - Compressor - OD - Chorus - Reverb - 5W valve amp. I'm a home player and finding it very difficult to keep the volume low enough not to disturb the Mrs, but high enough to not sound like I'm playing unplugged with zero effects and always seem to be on the cusp of too loud, or nothing at all.
Is it possible to install a small passive variable attenuator between the amp head and speaker as a single point of output volume control? I'm hoping this may let get the full benefit of the effects but at a greatly reduced volume. (Speaker is a Celestion 8Ω)
If at all possible suggestions please.
My other passion is firearms! Does that make me a closet Redneck???
It's just going to be another volume control after the amp volume.
I've used attenuators since a studio engineer lent me one for a session with my Marshall stack . I've a collection of 11 amps a few are vintage valve amps and I use them live and in my home studio too - but all with attenuators.
I use THD Hotplates and Weber Mass and they all work well. I've bought all of them used and they haven't broken. You have to make sure that the maximum power of the attenuator is ample for your amps.
My hearing is excellent, my neighbours still talk to me and I'm still married. Thanks to attenuators!
This is a good question. If you cant play louder anyhow, another link in the chain isn't going to make much difference.
Re-reading your initial post @Grampa (gosh that sounds like I'm being very condescending! lol), are you looking for a bit more finesse in dialing in a low volume in general due to your amp being NMV, or are you looking to get a tone you like from pushing those 5 watts hard at a lower volume? You say you want full benefit of the effects, but I imagine the compressor and/or drive has a level control you can use to get the same type of overdrive at a lower volume level. What is your drive pedal?
I see you're in discussions on an expensive attenuator. That may help but may be overkill if you're just looking for another volume control.
EDIT
I see you may still have the 633 Dragonfly RT. That's already got a headroom control for drive at very low volumes. The X2 OD has a level control as well. I don't see what an attenuator is going to bring as a solution that would be worth that kind of money.
I imagine it will be up to the task of taking your 5 watter down to domestic levels
And be careful with some, the ratings are optimistic - including Weber in my experience, but a 100W attenuator with anything less than a 50W amp should always be fine. The exception is those L-pads, which are usually called ‘100W’, but not suitable for any amp over 20W - the rating is based on their original application as treble attenuators for hi-fi speakers, where the 100W is the clean system power, not the power going to the speaker with an overdriven amp.
There might be a an attenuator optimised for low watt amps but I don't know about that.
I would still think there would be a way using the vol on your Tim and the power/volume knobs on the dragonfly to make everything work, especially if the Yammie does. I have both so I should have some shared experience. Hey, everyone's situation is different though.
I would look into a cheap Harley Benton attenuator or Bugera power soak. Passive and not a massive investment if you decide it doesn't do what you like.
