Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
Take one preamp valve from the 'good' amp. Replace each valve in the 'bad' amp in turn with it, and see if any of them is the problem. If that fixes it, just buy one ECC83/12AX7 to replace that one - you don't need to change any of the others.
If it *doesn't* fix it, swap all the valves between both amps - make a careful note of which positions they all go in and keep to it, just in case there's something position-specific. Don't worry about biasing the power valves at this point, it won't make enough difference to matter for a short test.
If it does fix it, that's where you may decide it's worth replacing them all or at least the power valves.
Others here might have other points to make or experiences to relate.
I've had a few valves from these guys and been very pleased with quality and service. HotRox and Karltone also been good for me
I last used valvetubeguitaramps.com and can highly recommend them too. I've had reasonable experiences with HotRox and Langrex also.
The yard is nothing but a fence, the sun just hurts my eyes...
