Guitarists with experience of fixing washing machines
There must be loads on these pages. Here is the mission brief
- Washing machine in utility room
- Washing machine is failing to consume fabric conditioner during cycle
- Suspected fault with water inlet to syphon fabric conditioner.
any veterans want to tell their story?
Ed Conway & The Unlawful Men - Alt Prog Folk: The FaceBook and The SoundCloud
 'Rope Or A Ladder', 'Don't Sing Love Songs', and 'Poke The Frog'  albums available now - see FaceBook page for details
«13
  • mike_lmike_l Frets: 5700
    Get a large hammer (A 4Lb club should do) and hit the washing machine in random places until it works. Or you need a new machine.
  • Col_DeckerCol_Decker Frets: 2188
    ^ we'll call that Plan B
    ^you should call it Plan A, Plan B is when you don't smack the crap out of the machine and go straight to Currys. Or Brighthouse.
    Or the pub.
  • EricTheWearyEricTheWeary Frets: 16372
    Lowest form of intervention would be to remove and degunk the tray you put powder and conditioner in and run a couple of empty loads before using conditioner again. The next stage would be to call my brother in law Andy.
    ^ Done that bit, and checked the incline on the washer with a spirit level in case its on the piss. All check out OK. It's going to be an engine out job I reckon. And its going to smell.
  • VimFuegoVimFuego Frets: 15844
    have you tried turning it off and back on again?
  • sweepysweepy Frets: 4214
    How old is the machine ?
    Do you work in our IT dept?
    That's their stock answer for everything.....
    edited October 2014
    The water that flushes the conditioner out of its container is probably pumped. If the nozzle isn't blocked, see if you can find the pump. It may not work because it is knackered, or it may have stopped working 'cos the control electronics have failed and are not telling it to work. It will have (probably) 2 connections to it, ground, and +V. See if you can get the machine to the stage where it is supposed to flush the conditioner, and check that power is being applied to the pump (there may be a voltage rating on a plate on the pump which will let you know what you're looking for: AC or DC, and how many V - if not, assume mains just to be safe and not blow up your multimeter).
    If its 3 or more years old I'd be tempted to scrap it, unless its something rather posh and spendy . Most machines are starting to get on their last legs by then, especially in a hard water area as we found out until we bought a water treatment unit
  • I kept a machine for 17 years before it needed replacing. And my current one is 8 years old. It has cost me approx £45 every 3 years, way cheaper than replacing it.
  • Just...don't use conditioner? Save a fortune.
  • SkippedSkipped Frets: 2371
    Just adapt. (Use a fabric conditioner that goes in the drum).
    When the grill failed on my free standing electric cooker (£139 from Argos) I went online to "research" all of my repair options.
    It soon became clear that the winning option was a George Foreman grill from Amazon (£19).
    How will Decker keep his silk lingerie soft?
  • chillidoggychillidoggy Frets: 17137
    Probably a solenoid valve not working, or a wire fallen off the valve. Should be a piece of piss to fix by anyone owning a VW Camper.
    Alternatively see my ao.com thread for a new Beko at £219 delivered.
    This is the bit where I think I'm gonna struggle tbh In the old days you could just turn the timer clock to the right bit of the cycle, but of course this one is all solid state so you can't. I guess I'll have to watch a whole cycle with a multi-meter attached to the solenoid to see if it gets a signal and fails to open.
    joy
    joy
    how the long winter months must fly by in the Decker household. :D
  • welshboyowelshboyo Frets: 1831
    is it EL34 or 6L6?
    joy
    This is a man with far too much time on his hands! My machine is 12-14 years old drill is chuck in clothes chuck in the condom which has soap in it turn dial to 4 go to pub for an hour or so then take wet clothes out the following day or the next.
    www.maltingsaudio.co.uk
    joy
    connect a buzzer to see if/when you have a feed. That way if you get distracted/knock one out you'll have an audible to say there's a feed, rather than try staring at a display for an hour or more.
