Hi folks. Not sure this is a thing, and the question may be academic but I thought I’d put it out there.
There’s a ton of information (and debate) over different types of buffers used before an amps preamp, and even in relation to effects loops send/receive.
What about between an amps power amp section and the speaker itself? I ask because I’m considering placing my CaptorX on my pedal board rather than sitting on top of the amp. That would mean the addition of a few meters of cabling between the power amp output and the speaker.
I’m sure a few meters may not make a difference, but what if it was 10 meters? 20? Does this ever become a problem in the same way cable impedance can be going into an amp?
Thanks.
Bandcamp
Spotify, Apple et al
You can fairly easily do the sums to work out what gauge speaker cable you need for a given power, distance, and speaker impedance. Or even more easily plug the numbers into an online calculator.
In your planned setup, though, just be aware that there's a much increased risk of accidentally unplugging your amp from the load. If the cable from the amp/speaker gets yanked out or forgotten when setting up.
If it's a setup at home that's unlikely to be altered by you or mischievous kids, then you'll be fine.
So if you're driving a 4-ohm cab, you would notice a difference at 100m - only half the power would be getting to the cab, and also the amp would be producing less power as it would be seeing an effective 8-9 ohm load. At 50m you might still be able to tell, but at anything much less than that, not likely.
Most 'proper' speaker cable is significantly larger than 0.75 sq.mm too, so the equivalent lengths would become even longer. If the cab impedance is 8 or 16 ohms it would also make proportionately less difference.
https://www.engineeringtoolbox.com/copper-aluminum-conductor-resistance-d_1877.html
I do a fair few gauge calculations, but when I'm running kilowatts tens of metres. Which is rather different.
(Despite the fact that their 117/120V will electrocute you just as easily if you make a decent connection to it, and at least in the past their attitude to earthing made it *more* likely, not less.)
Marshall had to sell their 1970s amps for the Canadian market with the 16-ohm output taps disabled because on the 100W models the output voltage exceeded the regulations.
