SPEAKER IMPEDENCE CALCULATOR
(so this was the "something new from Boss" thing the guy on The Gear Page forum was mentioning?).
A bit puzzling though that they should use a 'Boss original amp' for the Clean option, rather than a JC-120 model from their house brand.
I think this looks like a fantastic bit of kit, especially for practise and even if it's just a backup in case of amp failures. I'm not sure if the modes are modelled 100% on what they're labelled but the sounds are good.
It's the compact pedal version of the IR-200 so if you want something more complex it's there.
If you want to step up again you go to the GT-1000 CORE.
loved the GT1000 own amps so if this based on the clean/crunch amps then will do perfectly.
Will definitely have to try it out asap
