https://www.ebay.co.uk/itm/314092742034?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=w2ok-nrpqhg&sssrc=4429486&ssuid=5lQSA1xORfm&var=&widget_ver=artemis&media=COPY
Pricing seems to be all over the place depending on which page you look.
It's why I'm still gigging with my Vox Tonelab SE and LE as they are so easy to set up and use on stage. The GP200 is simpler, and has a lot of good gigging features.
And although £217 is a great price for an mfx with that spec, without being able to try one and put it through its paces to see if it can do the job I need and still sound good, it's a gamble. Ideally I'd need to try one on approval, or buy one from eg Thomann on a 30 day no quibble return but at full price which isn't ideal.
Sadly there's no local availability to try one side by side with Pod Go and a real lack of meaningful info on the GP200 out there. What's needed are some truly independent appraisals and comparisons with Pod Go from gigging players. I'm also mindful that the GP200 will likely need IRs to compare with Pod Go's v2.0 new cab engine and IR upgrade.
@topdog91 you've asked a good question. The Tonelabs are very gig robust but are also quite big and heavy, so I suppose I'm trying to find something that sounds good but that's smaller, lighter, yet still easy to use with a bit more flexibility. Perhaps I should stick with them because for my needs they just work and I'm probably just suffering from some minor GAS.
But the GP200 has some features I like that might make it good for gigging. These are in the other thread but I'll list here too:
Built in XLR balanced outs (as well as non-balanced outs)
MIDI
Groundlift
Staggered footswitches - such a simple solution to make switching much easier
Dedicated amp controls - (this was a feature I really liked in the Zoom G11)
Dedicated buttons to access each section quickly (modulation, reverb, delay etc) (a feature I really liked in the Mooer GE300)
Globally accessible looper
Built in drum machine (basic, but still a nice extra to jam to & drums can be looped too)
Initial & wait modes for footswitches - brilliant for teeing up something whilst you're playing
Cab off setting (global)
Patch level meter
180 sec looper
Customizable Display Mode (3 modes)
Magnify the patch names and numbers (great option for gigging).
1000mA (a sensible power requirement, unlike the Pod Go)
All metal construction
I think the GP200R offer is open until 31 December so I have a couple of days to mull things over.
HOWEVER having read the manuals and watched the videos I think it has a major problem for gigging. Although you can customise footswitches A B C D per patch to switch on/off pedals in stomp mode, the display only shows ABCD - so if you have a dozen patches for a gig there is no way you can remember which footswitch does what in each patch. Unless there's a way to name these switches per patch this important stomp feature is useless for a gigging player. Unless I'm missing something?
(Pod Go had a similar issue with its snapshots and it took Line 6 18 mths before it was upgraded with the ability to name & colour code footswitches)
I hope I'm wrong & I've emailed Valeton/Sonicake for clarification. If anyone here has bought one please let me know if I'm right?
