my impression has always been that the G12T-75's are good in a 4x12 but not by themselves...i may be wrong though.
In the future I want to replace the 75's in my 4x12 with some creambacks...i think they would sound so much better with my superbass
(I haven't tried the creambacks yet, or the amp in question, so that's why I left out the last bit you wrote )
The real problem was that until the Gold and the Creambacks came out, you couldn't really get more vintage-voiced speakers with higher power handling - the only real candidates were things like the G12-65 and Classic Lead, and they're pretty modern really. So V30s might have looked like the only option.
Although I still can't work out why anyone would put one in the little 5W Harlequin, it sounds *dreadful*. Literally almost any other speaker would be better! And as you know V30s are some of my favourite speakers .
[/quote]
Keep the 75s for a jcm800!
I haven't tried the Harlequin, but at one point I was sort of considering a Carrera (which as far as I'm aware is a Harlequin with more bells and whistles). No dealers here in NI, and I wasn't that far off ordering one without trying it, when (very luckily) a local shop got one in second hand. I wouldn't say it sounded horrendous, I did sort of like it... but nowhere near enough to buy it (and I agree with you, I don't think the V30 was helping). I think I sort of dodged a bullet with that one. )
Bandcamp
Spotify, Apple et al
Bandcamp
What a total pain in the arse!
First, getting the grille out is so difficult that I almost began to suspect it was glued in. First you have to remove the four screws (easy) and take the corner protectors off (easy), and then you have to try to get the grille out, without damaging either it or the cabinet. It's jammed in so tightly that at one point I seriously considered just leaving it... but there is a way: if you put oversized wood screws in the four holes so they grip the frame and don't go through into the cabinet, you can pull the grille out - it still wasn't easy, I had to lever it out by gripping the screws under their heads with pliers and levering against pieces of scrap wood on the edge of the cab, and slowly working it out by going round and round one corner at a time. Ten minutes! No I am not kidding.
Then I undid the speaker bolts, and tried to take it out... and found that it actually *was* glued to the baffle with a double-sided sticky gasket. WTF?!! There is absolutely no need for this in an open-back cab. More careful levering with flat screwdrivers under the edge trying to avoid indenting the wood... another five minutes, but again no damage. (Lever upwards only, so the indents are well under the rim of the speaker and hidden.)
I had a spare cheap Eminence to hand I wanted to try, so I put it in... and discovered that they've made the mounting circle at the upper limit for a Celestion, which is very slightly larger than an Eminence, so the bolts won't fit!!! I really wished I'd never started this now.
But the good news is that I managed to wedge the Eminence in just well enough to test the amp, and it sounds *miles* better. The horrible nasal middyness is gone and the amp now has some bottom-end - and that's not even with a good speaker. So I hope all I need to do now is find a different Celestion...
Sorry for the essay! I just needed to vent a bit about the utter bloody-mindedness of whoever thought it was a good idea to build an amp like this .
Bandcamp
