An M5 or M6 flat point dog grub screw would be about perfect.
(EDIT: I've edited this twice now because I was using the wrong terms. I'm ill and not thinking clearly so it might still be wrong!!)
The Hipshot retainer fits to the end of the fretboard and the screw go alongside the truss rod, where a Floyd locknut fits to the face of the headstock and the screws go into the face of the headstock, which would suit my build better
@Andy1515 or @Roland care to offer thoughts?
I'm pretty sure these clamps above are designed to cope with the additional pull of the fine-tuning or string bending/whammy levering and that the primary string tension is still held by the machine heads. So if you were to loosen all the tuners on the strat below after you'd clamped, I would put money on it not being as reliable a hold as if the tuners were either just left in tension or the strings held by individual grub screws:
Individual clamps, as at the other end of a floyd, might work, but that probably adds a needless complexity (not to mention the essential right angle string bend at that end)...
With a properly tightly clamped Floyd nut, you can remove the bridge from the guitar with the strings at full tension, by taking the springs off and lifting it out, take off the pickguard and do whatever work you need to on the electrics, replace the pickguard and bridge, put the springs back on and the guitar will still be in tune. Really... I've done it countless times.
When the bridge is out of the guitar there's the same tension on the nut - in the opposite direction - as if you have the nut clamped with no machineheads.
Floyd style, but individual string locks, and a bit more graceful than many.... but i assume it costs a bomb
Instagram
