My Fender American Vintage '60s Hot Rod Tele - from factory with 3 pickups - needed a string change and... I'd been curious about this for a while. I decided to sink the middle pickup under the guard to check it out.
It is still exactly as factory in terms of pickups - Texas Special middle pickup, paired with the with Custom Shop Broadcaster bridge and Twisted Tele neck. Obviously I changed the guard to one I had available. The middle pickup luckily is literally just held in place by some downward pressure of the guard with the pole pieces touching the guard. The S-1 switch integrated into the volume control that, when engaged, adds the bridge pickup to positions three, four and five, so those options still available.
I did a very brief sound demo in just the standard Strat positions (no S-1 switch depressed). The middle pickup by itself is a volume drop - of course, but I reckon 2 and 4 positions are definitely OK. The middle pickup by itself is a volume drop but... if you have quieter more acoustic like parts in a track or indeed whole tracks where you are just strumming along with the band, it is also usable. No settings changed between riffs.
And it looks better...
I've been intrigued by the Winyard Stealthcaster for a while:
https://www.winyard-guitars.co.uk/the-stealthcaster
I've not played one plugged in, but the two I played unplugged at one of the London guitar shows had superb necks - possibly the best I've had in my hands. I think they use hotter pickups under the pickguard to compensate for the volume drop. I really must audition one properly.
Not come across Winyard before.
I’ve found that the best ‘Strat’ sounds in the 2 and 4 positions come from using a low-output middle pickup.
OP here I thought that the output from middle would be less that than it is and that it would be a bit muffled, but it is not, it is pretty clear. It's a Texas Special so not especially weak for a single coil. Definitely usable to blend or to jangle along in a track.
