Borrowed this pic from google but will post an actual pic soon - Effectively my purchase is the same guitar - I spent a while yesterday at the Brum show looking/trying a few options in a few price points - Had a chat to a few trade colleagues about my situation that I wanted an acoustic that felt like my PRS to play etc etc - Found a Maton that was nice but not quite there
But the neck profile, nut width, scale length on this JWJ is far closer to the blue print I'm use to - Tried it - went back for a 2nd and 3rd play and my bank balance was reduced on the 3rd visit
So now a couple of questions - It is set up with 12's and a medium action and little relief - I will take the action down further but fine with no/little relief - After playing electric for nigh on 50 years, my right hand is limp and weak - I stroke the strings - Play mainly with a pick and a touch of 2nd + 3rd fingers to back up the pick at times for additional chord/melody support etc - Occasionally comp style with thumb and 2 fingers - So I will be continuing with this format
So I need/want to take some 'tension' away on the feel - I know it will be a bit of trial and error - But give me your thoughts
1) de-tune to Eb and either use a 1st fret capo and/or leave open on Eb - This way may well stay with 12's
2) try low tension strings - see Martin Flexible Core as an option - But never sold/used them - Others that are similar - I know it won't make any difference to the tension on the E/B unless I detune - But probably move to 11's
3) - Who has tried and favoured silk and steel and/or indeed silk and bronze (did not know the latter existed until today)
My gut feeling is to stay with 11's - I play 10's and sometimes 10.5" on an electric - I've seen/played acoustic guitars with 10's and even some who choose to use nickel electric strings (not for tone but to keep it slinky) - I'm not against this if it feels right and the feel to me takes priority - if it doesn't feel right you don't get a good tone anyway
It will be home use only - So no need to worry about volume - The silk n steel or silk and bronze sound like I should like them - Softer feel and warmer tone - My gut feeling is this is the way to go with 11 gauge - Think they offer 10 gauge - So who likes silk n steel or silk and bronze - what gauge do you use and any additional comments regarding feel/tension/tone
I bend little - Certainly more 1/4 to 1/2 note black Chicago blues style more than anything - Even adopt same format on an electric - that opening style bend on Still got the blues/Parisienne walkways, I never bend to the right note - I slide up to it (rightly or wrongly -m just me and my style)
Thanks - Nice I can ask you guys questions for once as I'm sure there are either acoustic players and/or electric players who play some acoustic, who are ahead of me in this process - Thanks
I wrote three-quarters of a long and (vaguely) thoughtful reply to your earlier thread, but never finished it ('coz I'm travelling at present). Nice to see that you made a great choice even without my advice.
On strings. Yes, you can go lighter, but wherever possible it's always better to retain as much string weight as you can and instead reduce tension. Everyone will say go round core (which is good advice and fair enough) but you can equally well go for a low tension hex core string. Just a different way to get the same result.
Some selections from those I've tried that might appeal -
In standard phosphor bronze:
For you I particularly suggest the R. Coccos and the Fisomas. (Both available from the excellent Lord of the Strings.)
As for silky things:
* Pyramid 307 Silver plated Germany $19 £10.50. Tension: very low. Longevity: fair. Squeal: medium-high. Feel: very soft and flexible under the fingers, also grippy. Sound: sweet, gentle, very slightly muted, but still has a flavour not unlike (but much more subtle than) a silk and steel sound. Comment: Shines at fingerstyle but versatile.
The JPs are really excellent. Quite outstanding. But they don't last, of course. Strings of this nature never do. How well do they bend? I have no idea. Bending is not my thing.
Jump onto Lord of the Strings and order one set each of R. Cocco, La Bella, Fisoma, and JP silk and bronze. Stay with 12s, or at very least 11s. All up that will cost you maybe twenty quid. Worth a punt!
I dare say I might have to work to make my picking right hand technique to be more 'positive' but 50 odd years of 'idol namby pamdy stroking' won't be easy to change
to add to your experiments, I would say give it a go with 13s on it and you might be surprised. I too went down the 12s to 11s for similar reasons. Hated the tinnyness and no volume and didn’t think the tension was any less ! Tried a couple of brands. I put some 13s on one of my acoustics and it came alive and was suprisingly easier than I thought to finger pick, maybe because even though they are ostensibly tighter I think the fingering is somehow easier with thicker strings.
Suprised me a lot, I’m mixed between 12s and 13s at the moment
quite a difference for sure, I would recommend a bit of relief for a softer feel
Felt unusual not having a G4U stand to go visit!
Re the strings ... my 2p thoughts.
Similar to you, I've really only started playing acoustic in the last couple of years, having only ever really played electrics. It took a little time and practice (and finger pain) to adjust, but now I like that the acoustic feels and plays very differently to an electric. I generally use 10s on an electric, 12s on my acoustics.
Give it some time on the acoustic before changing the tuning and/or strings. Yes, you'll play it differently and have to learn some different techniques, but (for me at least) that's part of the purpose of having acoustics - to develop different playing styles to work with the different tensions and string gauges.
https://youtu.be/4Dtk-n_34_o?si=9W6TA-1B4VwtYEdD
What pick do you use? I prefer slightly larger and thicker picks on acoustic vs electric.
12s feel like way too much hard work and I do genuinely believe the 11s sound BETTER.
12s give a hint more bass. Nice burst btw! Very similar to mine (below) - I've heard good things about JWJ - happy NGD!
My YouTube Channel
My YouTube Channel
Was the bridge situated further toward the lower bout like a Gibson as opposed to Martin?
My YouTube Channel
