The longer I play the guitar the more I gravitate towards lower output pickups, they just seem to let the sound "breathe" more, they're more dynamic, seem to be more detailed, and cope with gain just as well as high output pickups.
It must be a hangover from the days when amps were intrinsically lower gain and you had to push them harder. These days when high gain means cascading gain stages high output pickups just seem unnecessary. On the odd occasion where you may need to drive the amp hard there are very good clean boosts that can drive the amp harder than any pickup.
Maybe I'm just getting old?
I think we associate high output pickups with a louder, mid eq’d, compressed sound ( which is harder to make clean). Newer/more modern high output pickups sometimes use fancy neo magnets to be loud and uncompressed.
Any lower just feels underpowered, so I get slightly hot strat pups - Oil City Stone Tones in my case.
Anything higher is just too much, not as dynamic etc.
Depends what music etc you play I guess, but I think you're about spot on.
[1] Or absence thereof…
If you're a straight-into-amp person then I can see the use, or metal where it's sort of part of the tone, although active pickups sort of improve some of the negatives of hot-wound pickups ... I think?
Take my 1950s Dynasonics that I rebuilt for my red Telecaster project ... they have less turns of wire than an 8k P90 but they are 12.75k which should make them 'high output' in the books of the 'resistance figure slaves' ... they are in fact crisp, wide range and quite 'high fidelity'.
DC resistance is nothing to do with output ... it's just resistance.
My most popular pickups in humbucker form are 13k bridge and 10k neck. These are only just over PAF winding levels and thus output ... and the DC resistance is just a function of their wire gauge. My most popular Tele bridge pickup is one wound to 9.9k which is actually vintage output for a 43awg early Tele pickup ... not high output at all.
Also different amplifiers have different input sensitivities ...
My main caution here is generalisation: I generally spend a couple of hours a week on the phone to customers explaining for example the reason why 6k Strat pickup in the neck of a guitar can be louder than a humbucker in the bridge which they insist must be louder because of its higher DC resistance.
What I find is that preconceptions limit choice.
Filtertrons are low winding level, but not low output ... they have magnets twice the size of a PAF which allows them to be pretty much as loud as an average PAF ... but because they use less wire ... there's more clarity.
I've been using a fuzz face type circuit first in line (so using volume a fair bit to clean up) with t-tops.
Tone is rarely up full either.
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
