Son lives in a rented property. It's a relatively new build estate with a typical rectangle of lawn space which has been neglected by all tenants and landlord. Son has added to the trouble by having a puppy which digs it up and uses it as a toilet.
So, he's now got a rectangle of dandelions and bare mud. The landlord has asked him to make improvement to it before the next inspection in the middle of May - I think this was requested in February but it's rained every minute since.
New turf would be an heavy undertaking and costly. It would need the top scraped off and disposed off, then fresh turf rolled out and maintained. Would probably work best but cost seems to be too much.
I've always believed that seed would give a better result, but what to do with the dandelions that are there? Weed killer might shift them but then that might delay the sewing of the grass seed. Part of me thinks that if we can get seed to germinate enough to fill the gaps, then mow it regularly then it should give a full green coverage even if much of it is dandelions rather than grass.
He'll need to keep the dog off, especially while it takes hold, but probably needs a long term solution for that too. I'm going to suggest building a gated fence to restrict the areas he can get to.
Fiskars stand-up weeder for the dandelions.
If you can pour water where the bitch pees it will dilute it and stop it killing the grass. It's actually very good fertiliser.
If you don't get the dandelions root out completely (or kill) they will come back.
I'd do as you have suggested "...get seed to germinate enough to fill the gaps, then mow it regularly then it should give a full green coverage even if much of it is dandelions rather than grass."
If you (your son) went round the existing visible dandelions & with an old 6-7 inch kitchen type knife stab the ground around the dandelions at about a 45º angle to cut the tap root below the soil. This will retard the growth enough to re-seed the area & outcompete them.
As you say, they probably will return or blow in from other gardens, but you'll have established the new grass by then & it's just maintenance after that.
You'll need netting to stop the birds scoffing the seed & keep the dog off.
Not sure as different rental properties have different agreements.
Not great from a green (!) perspective perhaps, putting plastic onto, and then into, the soil, but if it's laid properly, any contamination should be minimised.
However, (a) it's not cheap and (b) you shouldn't really just stick a layer of astroturf down on the soil (which adds to the not-cheap aspect). Probably not a cost that you'd want to incur as a renter unless you (he) plans on being there for a few years.
Would that be acceptable?
Cut it as required, and don't collect the cuttings.
Grass is hardy stuff and will recover quickly, especially now it's getting warmer.
Just makes sure to keep the dog off it, or at least not leave it on the grass long enough to dig it up again.
If your son is responsible for the lawn, (unlikely imo but depends on the tenancy agreement) then astroturf would be the best and quickest solution.
We have just seeded our lawn in a few patches (under trees), and it has already started to take, so a decent seed designed for people with dogs can help. There are a few lawn seeds out there with more dog-resistant properties.
Lawn feed will also help, etc
