But for restringing find a video that you can follow and use that method; it's not a dark art and with practice will become really easy.
Standby for a daft string question to then….
It appears my guitar was fitted with Fender 80/20 Coated 12/52 strings. They don’t get great reviews for longevity. Looking at other brands such as Elixir (as mentioned) and D'Addario they don’t do 12/52. It’s either a 11/52 or a 12/53.
Generally, it's best to think of string sets in classes which, for short, we call:
"10s" - typically 10-47 but there are variations.
"11s" - typically 11-52 but many variations
"12s" or "light" - most often 12-53 or 12-54, but 12-52 and 12-50 are both quite common too. The difference between a set of 12-54 and a set of 12-50 is only significant within one particular make and style, and even then isn't huge. .
"bluegrass" - always 12-56.
"13s" or "medium" - usually 13-56.
In theory, the gauge is the diameter of the string measured in some arcane unit I can't for the moment remember (but it has something to do with inches). In reality, it is best thought of as an arbitrary number, like a "number 4 bolt" or a "size 10 dress" - or a "000 guitar"! The nominal gauge of the string and the actual gauge of the wire from which the string is made are seldom the same. So just think of string gauges as being like shoe sizes - more is bigger, but they don't correspond to any particular measurement.
SO - each of these gauge classes (11s, or 12s, for example) is heavier than the class below, and you may very well need to adjust the neck if you change too far.
HOWEVER, every manufacturer has its own style. Fender 80/20s, for example, are light so far as 12s go - almost like average 11s. Elixir strings, in contrast are heavy for their gauge - Elixir 11s are probably as hard or harder on the fingers than Fender 12s.
No brass string (aka "80/20") lasts very long. People buy them for their sound quality, not for longevity.
Phosphor bronze strings usually last longer.
Coated strings last longer again, but feel soapy and don't sound quite the same.
NOTE THAT long life isn't simply a matter of coating. Heavier strings last longer than light strings (but are harder to play). Hard strings last longer than soft strings (but are harder to play). Coated strings last longer than uncoated strings, but don't have quite the same sound and can also feel soapy and unpleasant.
Elixirs last very well (as they should at their high price!) partly because of their coating, but mostly because they are very hard, high tension strings. If you want the long life of a set of Elixirs at a third the price, try a set of Jim Dunlops - they last practically forever because they are even harder and stiffer than Elixirs. (And you need some serious muscle to play them.)
SHORT ANSWER: Look for a nice set of 12s (12-50, 12-52, 12-53, 12-54, it won't matter) in a medium to low tension. Examples I recommend include Darco, DR Sunbeam, Dragão, Galli, GHS, La Bella, and Newtone. Don't worry about longevity, generally speaking very long-lasting strings are expensive, hard to play, or (usually) both. Just get nice strings that you enjoy playing.
I should have qualified my answer a little more Moving up or down a gauge in the same brand/range of strings will most likely not need any adjustment.
i like and use the simple Taylor restringing video, it always comes up on google, I can’t be doing with kinks, and numbers of wraps and wind upwards/downwards. Best advice I’d give anyone because no-one seems to say it on the videos is to always tighten strings ANTI-CLOCKWISE for every tuning peg irrespective of what side of the headstock it is on. (And clockwise to loosen)
those strings on it are fine and last long enough. The other recommendations are fine of course, but those are ok to start with unless they are rusty already (such as they’ve been on the guitar for ages before you got it). Make a note on the same piece of paper of when you change strings and what to. When you change them again, make a note of what you did/didn’t like about them. Do the same each time you change m especially to a different set, and then you build up your knowledge of what you and your guitar like
enjoy, hope the guitar gives you lots of fun
I absolutely love them. 11-52 on my D35.
I also use 11s on a Dreadnought-size acoustic and they sound fine to me, not really noticeably different from 12s.
This isn't my thread @BillDL but but as a blind guitar player I've tried to figure out stringing a few times, broken my share and sorta got a method. But this text heavy explanation of a few of the finer points was super useful.
Something like...
https://www.toolstation.com/minotaur-side-cutters/p85564
