Cable Colour
maltingsaudiomaltingsaudio Frets: 3259
Just ordered some Custom Lynx tour grade cable to make up some Guitar leads (NB excellant cable been using it for years and just as good as Van Damme) and the question of what colour to buy came up. Never really gave it much thought befor as cables should be Black right?
( I bought Copper colour , was going for yellow but bottled it!)
www.maltingsaudio.co.uk
  • HAL9000HAL9000 Frets: 10072
    edited May 16
    Red sounds better :-)
  • timmypixtimmypix Frets: 2554
    I have coloured cables for when I'm using a 4CM setup, with corresponding coloured dots on amp/POD. Just makes setup quicker when you can see which cable's going where!
    Tim
  • HeadphonesHeadphones Frets: 1051
    Don't worry, they'll always end up black...
  • Danny1969Danny1969 Frets: 11014
    Van Damme Blues series, but mainly because I need the extra cores. Other than that all cables should be black as bright coloured cables look shit in theatres and dark stages when professionally lit.
  • stickyfiddlestickyfiddle Frets: 28753
    Black. I add a couple of electrical-tape-stripes at the ends so I can tell which is which when plugging in several or if something dies I can remember which one.
  • RolandRoland Frets: 9129
    Danny1969 said:
    … cables should be black as bright coloured cables look shit in theatres and dark stages when professionally lit.
    My guitar cables are black. However all my XLRs are red because I was fed up with them getting stolen.
  • scrumhalfscrumhalf Frets: 11680
    You are Eric Johnson and I claim my £10.
  • ICBMICBM Frets: 74494
    Multicoloured woven cloth.
  • OffsetOffset Frets: 14034
    My guitar cables are day-glo yellow and day-glo orange.
  • I'm not a big fan of coloured cables in general but my pedalboard-to-amp cable (longer than the rest) is blue just to make it easier to pick out from all the other black ones.
  • guitargeek62guitargeek62 Frets: 4386
    This - nail polish works well
  • bloodandtearsbloodandtears Frets: 1759
    @Danny1969 does the Blues series come in different colours? asking for a friend..
    My trading feedback
  • steersteer Frets: 1233
    I usually avoid black cables. If you buy a different colour you are less likely to get any other musician picking up your cable after a gig thinking that it is theirs.
    I don't think so yet  but I am always on the look for new mulitcore cable
    I never used to think too much about cable colours until I was taken to the back of a theatre and shown how things can distract, like the power on light of an amp or the reflective glow of a bright green cable or similar. This guy used to tape over the lights on amps and wedge monitors to stop the distraction. I disabled the  light on my amp and have never re-enabled it.
    You can buy rings which are numbered for XLR's and Neutrik jacks. I don't do this myself, I use heatshrink. I tend to use a lot of looms for drums and stereo feeds so not that many actual XRL's
    I wouldn't use 4 separate cables for the 4 cable method, I use mulicore and 5 pin male and female XRLS either end. I have one 3 metre and 1 4 metre. For big stages I can join them together for 7 metres between amp and board.
    For a simple send /  return from amp effects loop to pedal board just use 2 x XLR to jacks convertor wired pin 1 = both grounds, pin 2 = send and pin 3 = return and then a mic cable between them for the length. Need a longer run then just stitch another mic cable in there
    For stereo IEM down a single mic lead convert both sends to single ended by shorting pin 3 to ground then use pin 1 as common ground, pin 2 as left and pin 3 as right.
  • p90foolp90fool Frets: 32391
    I always buy colourful guitar leads just to make the spaghetti de-tangling easier at the end of the night.
    Apart from that, my mains leads are black and my speaker leads are either white or orange, depending on whether I salvaged them from a lawnmower or not.
  • CavemanGroggCavemanGrogg Frets: 3466
    Should of gone with day glow pink, orange, green, or yellow.  No other colour cable is capable of providing tones a good as neon day glow coloured cables do.
  • fretmeisterfretmeister Frets: 25567
    Yukihiro Hayashi, the boss of Free The Tone pedals has actually argued that the colour of the insulation makes a difference. Different colour, different properties.
    I'm just glad to have a non-financial reason to not buy from his company!
  • gatheredinsonggatheredinsong Frets: 728
    I recently bought purple XLR leads to run from my pedalboard amp because I'm having a mid life crisis.
    this is also me...
    My trading feedback
  • freakboy1610freakboy1610 Frets: 1247
    I got a purple curly one last year (no reason...) and a straight purple Mojo Cables one at The Guitar Show.
    Link to my trading feedback
