Hey guys,
I know there is someone here who can help.
I dont use pedals, I play lead guitar but have never needed to mess with them, I use Line 6 Flextone II XL with the floorboard so everything I have ever needed is already in there.
My Rhythm guitarist is going to be playing the solo from whiskey in the Jar. He also has very limited experience with pedals as he has never played lead before ever. We need something he can hit to give him something that boosts him over the rest of the band for the solo part. He is using a peavey bandit combo, it sounds really good.
Can anyone please give a little advice to a pair of pedal virgins as to how we might achieve this?
Many thanks
Boss SD-1, seems to work well with every amp there is (certainly with the ones I've tried it with).
It's also cheap, readily available, and almost indestructable.
I didn't think about the pedal in the loop. A clean boost will work well there, my preference is the MXR MicroAmp.
Don't use an overdrive pedal in the loop, it can damage the amp.
+1 to this. You can use it as a clean boost or add some grit as required and there is a useful tone knob.
There seems to be a lot of interest in Klon type pedals at the moment and the EHX Soul Food is the level entry version. Same knob set up as the SD 1 but it will sound a bit fatter. Possibly not as indestructible in the long run though.
IIRC the SD 1 is a modified Tube Screamer type circuit. Tube Sceamers are the classic answer to the 'what boost' question but they can be a bit nasal sounding through a 1x12 like the Bandit. So a TS type with better eq might work, like the Digitech CM 2 which is also pretty cheap.
If my rhythm sound is quite clean (for sets with Long Train Running etc), then when I go to solo, I use the tube screamer only.
If my rhythm sound is already quite dirty (eg for Livin' on a Prayer-type sets), then for solos I either use the tubescreamer alone or both together if it's not cutting through.
If my rhythm sound is already very dirty (eg for Van Halen-ish sets, where I might have the tubescreamer on for the rhythm parts anyway), I use the vol pedal for solos.
The pedals I use are a Keeley Ibanez Tubescreamer 4x2 Turbo and a Morley Little Alligator volume pedal, they're really high quality, don't affect the tone negatively, are infinitely adjustable, and bomb-proof.
Eqd Speaker Cranker clone
Funny, I was using an SD-1 into a dirty amp on NYE, when engaged the volume went up.........
