Fantasy Dual Pedals
thecolourboxthecolourbox Frets: 9915
So in the vain of EHX multi combination pedals (Turnip Greens anyone?), what dual pedal combinations would be cool and nicely whimsical?
I vote for:
Frammy - EHX Freeze + Whammy. So as soon as you kick in the octave up the chord you played at that moment gets sustained for you to do a whammy solo over the top
Phase360 - Phase 90 and EHX 360 looper. Would let you do a tempo sync phase pattern/loop
Deluxe Memory Muff - DMM + Big Muff. Instead of having your delay repeats effected with modulation sounds, get them to smack you in the face with fuzzed repeats
soundcloud.com/thecolourbox-1
  • DesVegasDesVegas Frets: 4614
    I'll take a Deaser please. A delay and a phaser
  • Or a Phalay if the other way around :) good choice
  • darcymdarcym Frets: 1297
    Octavia with a tube screamer after it you can use one/other/both
  • How about a Whamamin - a whammy pedal controlled by a theramin type gadget
  • xSkarloeyxSkarloey Frets: 2962
    The Boss SOD/HM/R or the "Sodomiser" as it would no doubt be affectionately known to its fans (mainly wooden church burning Norwegians high on Jagermeister no doubt).
    This is essentially a dual drive pedal consisting of a Super Overdrive, the classic (no laughing at the back there) Heavy Metal HM-2,  with added Reverb for general awesome church like sounds of doom.
  • http://i1278.photobucket.com/albums/y513/phlplls/Mobile Uploads/2014-06/ADC582EB-0693-41F4-A2BD-0B25559878A9_zpserhzafyv.jpg
    This is the dual ( assuming I can include those with two effects but one footswitch) pedal that I had made. Auto wah and boost in one, modest aspiration really. Boowah? Autoost?
    I did, however, give it its own name: http://i1278.photobucket.com/albums/y513/phlplls/Mobile Uploads/2014-06/8B35ECD5-E1D4-4EAA-929F-4547585DE9FD_zps6knmssgs.jpg
    My other fairly modest ideas for dual pedals included Tweed Box ( tremolo and tweed style OD) and Dick in a Box ( spring reverb and overdrive, named in honour of Dick Dale).
    ^Dick in a box can be really painful.
  • hugbothugbot Frets: 1528
    I really want EHX to do a B9/C9 with a freeze built in, so it can hold organ chords as a pad.
  • I only use delay and an overdrive/boost, so a TC Flashback X4 with a Spark Mini on the end would do me.
  • Whammy with a delay in it. Though you want dirt after Whammy and before delay, so that would be poo.
    I therefore propose the WhammyRatDelay, which is essentially what my new pedalboard will be :)
  • photekphotek Frets: 1469
    edited February 2015
    Chive
    Amp channel switcher and a drive pedal so I can use the clean channel on my amp with the overdrive then stomp once to turn the drive pedal off and swap to the drive channel on the amp.
  • mike_lmike_l Frets: 5700
    Only if you're doing it wrong........
  • I had a whole list of In A Box names at one point. Funk In A Box - auto wah and compressor. Big Hair In A Box - 80's style chorus and delay.
    I need a proper hobby...
    And an expression pedal that can control the modulation or be a volume pedal.
  • GassageGassage Frets: 30997
    I want a TC SCF with a Lesile Sim....the snappily titled TCSCFSLS.
  • d8md8m Frets: 2434
    A TU-9.
    Just two TU-3s side by side
  • d8m said:
    A TU-9.
    Wouldn't that be three? Like it. Presumably one keeps t'other in tune?
    photek said:
    Chive
    That is an excellent idea, presumably if you can't wire up a single switch to do two things, a Boss style footswitch could potentially push two switches inside...
    So you could pitch shift your delays? That would be awesome, especially if it extended to shimmer reverb, where you could vary the shimmer interval with a whammy pedal. I'd call it a Shammy (pronounced as Chamois)
    d8m said:
    A TU-9.
    3^2
  • Love it
  • This one is not a mix of two existing pedals, but builds on one for a better usage potential.
    I would take the EHX random tone generator, and instead of it spurting out random synthy noises, it would blast out well worn classic rock cliches instead, just the untreated guitar sound. This could then be used instead of watching gear demos, or having shop assistants demo stuff for you, when wanting to hear how a pedal or amp sounds.
    Well worth the purchase if it means i don't have to watch the chuckle brothers demoing gear in their shop
