So in the vain of EHX multi combination pedals (Turnip Greens anyone?), what dual pedal combinations would be cool and nicely whimsical?
I vote for:
Frammy - EHX Freeze + Whammy. So as soon as you kick in the octave up the chord you played at that moment gets sustained for you to do a whammy solo over the top
Phase360 - Phase 90 and EHX 360 looper. Would let you do a tempo sync phase pattern/loop
Deluxe Memory Muff - DMM + Big Muff. Instead of having your delay repeats effected with modulation sounds, get them to smack you in the face with fuzzed repeats
soundcloud.com/thecolourbox-1
Octavia with a tube screamer after it you can use one/other/both
This is the dual ( assuming I can include those with two effects but one footswitch) pedal that I had made. Auto wah and boost in one, modest aspiration really. Boowah? Autoost?
I did, however, give it its own name: http://i1278.photobucket.com/albums/y513/phlplls/Mobile Uploads/2014-06/8B35ECD5-E1D4-4EAA-929F-4547585DE9FD_zps6knmssgs.jpg
My other fairly modest ideas for dual pedals included Tweed Box ( tremolo and tweed style OD) and Dick in a Box ( spring reverb and overdrive, named in honour of Dick Dale).
Chive
Amp channel switcher and a drive pedal so I can use the clean channel on my amp with the overdrive then stomp once to turn the drive pedal off and swap to the drive channel on the amp.
Only if you're doing it wrong........
I need a proper hobby...
Just two TU-3s side by side
Wouldn't that be three? Like it. Presumably one keeps t'other in tune?
That is an excellent idea, presumably if you can't wire up a single switch to do two things, a Boss style footswitch could potentially push two switches inside...
I would take the EHX random tone generator, and instead of it spurting out random synthy noises, it would blast out well worn classic rock cliches instead, just the untreated guitar sound. This could then be used instead of watching gear demos, or having shop assistants demo stuff for you, when wanting to hear how a pedal or amp sounds.
Well worth the purchase if it means i don't have to watch the chuckle brothers demoing gear in their shop
