Interestingly, I just opened up the control cavity and a fair bit of sawdust fell out, presumably I'm the first person in there since it was made.
Issues:
- High E comes very close to the edge of the board, I think this is due to the bridge being in the wrong place by about 1mm as the low E runs parallel to the top of the fretboard and the nut looks evenly cut.
- Barely any fret left - seriously, about 0.1mm and completely flat across the top, making chords sound unclean, however it's really easy to play in every other way.
- Large scratch / dent across the fretboard from the 5th to the 7th fret right in the middle, like someone dropped a running drill on it. You can't feel it but you can see it.
- Pickups are ok, not bad not good, just middle of the road, buzzes like anything given half an excuse.
Good stuff:
- Neck is flat as anything
- Seems to hold its tuning quite well even though the tuning pegs are the type you only ever see on cheap 70's/80's guitars and one has been put in wonky.
- Really like the maple neck with black blocks
- Not overly heavy
- Well finished
I guess the next step is to figure out what I'll be able to do myself and what I'll need to get a professional to do, I'm only a hop skip and a jump from Feline so I could drop it in there no problem.
Any advice on the above issues, or is it a fools errand to throw money and time at a guitar that was a bit crap to start with?
I wouldn't bother spending money on a refret - but if you ever fancied learning to do it yourself this will be a good contender
as its a bolt on neck you may be able to pull it back in line. take it off, have a look. if you cant get it in line that way the quick cheap fix would be to re slot the saddles closer to the bass side. the proper fix would be to plug and redrill the neck holes for proper alignment
if you can;t feel the scratch don't worry about it
I would check the pickups in there as well - are they original? worth checking if someone ever did a dimarzio upgrade - you get lucky occasionally
Instagram
if you did go for a DIY refret i would refinish the board too, it will take care of that scratch. but i would expect those frets to come out in the usual way without too much damage to the maple or lacquer, just need a bit of heat first
i can't say the neck would need a shim without having it in my hands, but if there is any play in the neck pocket and screw holes you may find you can get it into a better position just by loosening the screws, pulling the neck into position and retightening.
Instagram
Dive in and learn some skills, empower yourself and save yourself money on setups, etc in the future. There's a whole forum here to get advice from so what have you got to lose?
I still like these early dimarzios much better than the new ones but even the square foots go for under £50
Nothing better about square feet, they are just on of the only dating features you can see without breaking out the multimeter.
Tony is still right though, £80 - 100 for the pups, and the guitar may go for not far off that without them and no different with.
Instagram
Instagram
that is a really cool looking guitar.
like others have said...keep it and fix it up. might be worth selling those pikcups though (if you dont like the sound) and getting some cream pickups from Ash.
