How does it cope range wise?
I'm after a one stop shop OD pedal that can go from classic rock through to modern boost.
I don't like it to be honest - I find it a bit middy and clangy, not as boxy as the SD-1 but without the warm fuzziness of it either. Some people seem to like that though.
I've had the OD-3 and the BD-2 at the same time. The OD-3 is much fuller in the low end than the BD-2 - almost as if it is boosting the low frequencies but it doesn't sound muddy at all. It is capable of quite a lot of gain and I found even with the gain control set to minimum, it still added a tiny little bit of hair to notes (using a Strat with the guitar volume full up). It is very dynamic though and reacts well to guitar volume changes. It is also capable of a large volume boost as unity gain is quite low down on the volume dial.
I found the gain on the SD-1 to be a little smoother overall which is why I kept it and sold the BD-2 and OD-3. SD-1 is a lot more "middy" though - the OD-3 is more transparent to my ears but with a noticeable "oomph" in the low end.
I always thought from what I had heard that it was pants though.
Further to my previous post, although I kept the SD-1, it is currently off the board and my No.1 choice for what you are trying to achieve is the TREX Moller Overdrive. It is like a 2 in 1 pedal - a TS style drive (with blend control) and a separate clean boost which can operate independently of the drive side of the pedal or in tandem (the boost is post drive). Another alternative is the Hardwire CM-2 Tube Overdrive which is ridiculously good value.
Apart from the bypass bleed, the SD1 is awesome. Assuming you use it as a boost, anyway.
Had a monkey, didn't like it. Have a CM2, love it.
Shopping for one at the moment to replace the dyna drive, which is very good for the 25 quid I paid, but isn't quite what I'm after.
I'd agree with everything @icbm has said. It's less warm and fuzzy around the edges compared to the sd-1, but this means it's a really great, clear drive when used as a standalone overdrive.
If I had a Marshall though, sd-1 every time. And ds-1. And ds-2. And df-2. Get all of them
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
