HB TE-70 Rosewood Tele - Oh Bugger!
Ordered 1pm Tuesday and delivered 9am Friday. Opened the the box and oh bugger! Mega problem!
It looks great and despite my hardest prejudices it plays good too! Mega problem is that it seems to need almost nothing doing to it!
Only cosmetic blemish is round the neck pocket but very minor and too small to photograph. Wiring works too though the tone control does nothing until it is almost fully off. Pickups are usual Wilkinson quality - good but not great. Fret ends are not super smooth - if this was £250 it would be ho-hum but at £107 you lower your quality bar to the bottom and accept such minor things.
Initial thoughts:
-New pickups, maybe new pickguard to accomodate larger neck pickup
-4 way switch
-Drill body and add ferrules for string through body
-Tidy frets
-New nut
-New bridge possibly
-10 guage strings
but not necessarily in that order...
  • underdogunderdog Frets: 8334
    Just had same experience with the explorer, plugged it in to little practice amp I keep at work, and other than electric and fret polish it's a hell of a guitar.
  • stimpsonslostsonstimpsonslostson Frets: 5422
    edited February 2015
    This thread NEEDS pictures!!
    Well done, I considered one of those too! My TE52 genuinely surprised me- it's fine, a perfectly serviceable guitar for £90! As with yours the wilkinson p'ups are nothing special, but they work just fine.
  • MegiiMegii Frets: 1670
    Your description of the tone pot sounds like it's a linear taper one - FWIW I'd fit it with a log/audio taper one instead, probably a 250K if dealing with typical tele pickups. But sounds like a great buy, the "problem" not withstanding... :)
  • ChalkyChalky Frets: 6811
    @Megii - thanks for the advice, will get a log 250k pot sorted.
    No worries, hope it helps - should do anyway, from experience. That is a really handsome looking guitar you've got yourself there.
  • impmannimpmann Frets: 12697
    How heavy is yours? I have been considering buying one but reports of them being boat anchors has put me off
  • @impmann Yeah, my TE30 weighs a tonne. Heaviest guitar I own. There's an exact weight for it in my mod thread for the challenge. Can't remember what it was.
    @impmann - My TE70 weighs 8lb 4oz. So yes its a bit heavy for a tele.
    Changed the neck pickup to a Harmonic Design mini strat pickup. Surprised at how bright and airy it sounds even without changing the pots yet.
  • RolandRoland Frets: 8816
    @TheGuitarWeasel. How easy is it to make a mini Strat pickup to fit a Tele?
  • OilCityPickupsOilCityPickups Frets: 10949
    Like the 'Californian' at the bottom of this page you mean?
    The one at the bottom of this page - http://www.harmonicdesign.net/allpages/teles.html
    Just ordered a couple of the Oil City tele pickups - Hard Man and Alligator 90 to try. Might try a real P90 when I've cut a bigger hole...
    Doh! Got the new OilCity pickups but thought the Alligator 90 was a neck pickup! My excuse is I was multi-tasking at the time :) Oh well I've got to cut a bigger hole now.
    Ok so the Achilles heel of this guitar is the set of tuners. Thought they were ok but they drift out of tune just too often so need to find some more. Any recommendations or sellers of best slotted or locking tuners?
  • DaleftyDalefty Frets: 509
    Like Kluson machine heads?
    DaLefty
    Both dog and owner available for stud, please contact DaLefty if interested
    Mine has Axesrus locking tuners instead of the Harley Benton originals. £22.50 IIRC
    DaLefty
    Or clones I should say, in 8.5mm.
    DaLefty
    Klusons would be fine and will check out Axesrus...
