New Old Solid State Amp Day
I just got given this for about a hundred quid's worth of work, or maybe slightly less - that was the upper end of the estimate.
Marshall Mosfet 100 Reverb, second version. (No pull-EQ on the lead channel.)
Fully working apart from some crackly pots, extremely loud, very well-built and really pretty good sounding. It doesn't even weigh that much, unlike the Peavey I got a couple of weeks ago - only 42lbs.
This second version has a much cleaner clean channel than the original one - almost Fendery - and although the overdrive only has a single tone control it's capable of a reasonable variation (the preset EQ is equivalent to the bass up full and the mid at halfway on a standard Marshall tone stack, the control is the treble) and just sounds good anyway, as long as you want something that effectively sounds like a Guv'nor pedal into a clean amp.
So with the Peavey and this, now I have a 220W clean/dirty/stereo rig that's only the same weight as my Trem-o-verb and is much easier to carry! Gig bag on the same shoulder as the hand carrying the Marshall and it's reasonably balanced.
Shame I'm not in a gigging band (as a guitar player) at the moment or I'd be well set up...
Feedback
The Peavey is louder, by 1dB. Or at least as best as I can tell with the dB meter on the other side of two closed doors to stop it overloading, anyway!
But in fact that's with the Marshall limited to only just over half its true maximum power by driving an 8-ohm speaker, whereas the Peavey has a 4. So the Marshall would win into a 4-ohm cab of the same sensitivity, probably.
The Peavey also has a much harder, painfully penetrating tone when it's really turned up full, whereas the Marshall is warmer, fuzzier and (slightly) 'sweeter' sounding. The Peavey has a chunkier clean tone though.
Both are far, far louder than I will ever need - just in case anyone is wondering, I don't actually want to use them like that! The purpose is simply to have a portable amp that won't ever be limited by volume on a clean sound with pedals in front, which is often a problem with apparently powerful solid-state amps in a live situation.
Trust me, you don't ever want to stand next to either of them cranked into power-stage overdrive if you value your hearing...
