Hello.
I just got a second hand Fender Mustang I and I've been playing for a while until I got a little painful shock from the strings.
I was barefoot and there is a popping sound every time I touch the strings. Also there is the weak buzzing sound coming from the amp when no metal parts are touched. I have previously used my PC to play and no notable buzzing or shocking was present, however there was a little popping sound when guitar was touched.
What should I do? Is it the amp's grounding issues or guitar's grounding issues? I switched to another socket and wore slippers to continue playing and no further shocks were received. However the popping and buzzing stayed.
Help.
If the buzzing goes away or reduces when you touch the strings, they are grounded. Although that is in itself a hazard because that's how you're getting the shock, it's not the cause of the problem.
First get the amp checked. If it's OK, get the wall supply checked.
contactemea@fender.com
I was playing Hot Rats at the time.
DaLefty
I once stuck a fork in a live toaster and it was a similar experience.
Anyway, not to be recommended.
Instagram
