vibrating PUP in LP
HootsmonHootsmon Frets: 16076
any harm in putting some foam underneath the pick up?
I have narrowed the rattle down to the PUP....when I place finger on it...heh prestae the buzzin' stops
tae be or not tae be
  • Nah won't do harm.
    My scratchplate on the strat buzzes at some frequencies. It's annoying but not noticeable at volume, nor does it affect anything but silent practice.
  • WezVWezV Frets: 16967
    do whatever works as long as its non invasive.
    When i took my 96 epi apart a couple of years ago i found blue tack i had added under the neck pickup when it was brand new.   i used the blue tack to find the rattle then left some in their as a temp fix.... the rattle never returned in 15 years
  • ElwoodElwood Frets: 455
    Are the springs on the pickup ring loose and ineffective. A couple of longer springs might increase the tension and stop the rattle.
  • streethawkstreethawk Frets: 1635
    Foam will do it.
  • zenzeypherzenzeypher Frets: 265
    nothing wrong with that. I usually pack foam under p90s and leave little notes. I quite like what fender are doing with the surgical tuning and wondering if I can do the same on my LP.
  • HootsmonHootsmon Frets: 16076
    eh?
  • SassafrasSassafras Frets: 30320
    I thought Gibson were doing the surgical tuning thing with their robot tuners.
