Let's face it, everything, well almost, seems to de described by a number.
Are there just too many numbers?
How do you handle all the numbers we guitarists have to deal with?
Is there an easy system of writing them all down, a notation of numbers so to speak, so we can see the wood for the trees ( or the frets from the fingers?) ( or the beats from the intervals)
So what has a number?
Strings
Frets
Fingers
Intervals
Sequences
Positions & boxes
Groups & shapes etc
then there is the music itself:
Beats in the bar, note duration, time signatures and the bars of course
Tempo, Beats per minute
what else have I missed?
What I am asking is - how to write this stuff down,
ie, play the 6th string on the 4th fret with your 2nd finger which is the root or 1st interval, and which is the first step of the sequence we are about to run through...
It is almost approaching novella proportions just to write a couple of octave scale this way.
So, there must be a better way, surely
Guitar teachers and wise people of the FretBoard, how do you describe these things, is there any standard way?
If not, then lets invent one...
Title - 'The Numerical Burden Of The Modern Day Guitarist'.
Pushing it just a bit with that statement methinks! A lot, yes. Every? Hmmm...
@ChrisMusic is actually right.
Whilst I much prefer traditional notation from a music point of view it does have a couple of distinct issues in guitar transcription. Firstly is the inability to notate certain techniques. The guitar has more note approaches then any other instrument. A bend, a slide, a hammer-on, a bend behind the nut and a whammy up can all be read as the same.
A second issue is the rhythmic style in which the guitar is played. A lot of strummed rhythms for instance are generated by vary the strings struck. Transcribing it accurately and without any other direction would lead to a confused and unreadable score.
Despite standard notation being an established and IMO brilliant system (not a tab fan) it does have certain limits when transcribing guitar parts. When scoring I will include information for clarity but as ChrisMusic pointed out you are varying from the system.
Mike Stern is an avid user of scores, practising using Bach scores etc, but even he adds which finger he uses under the notes.
Feedback
take middle C - half it, half it again (c at the end of the piano), half it again ... half it 4 more times and waddaya got? 120 BPM.
now, scales described in functions of a major scale (ie 1 2 b3 4 5 6 b7) are simply holes punched in a pianola - for an instance of a bar they mean one thing - next chord voicing they mean something else. So make your life easier - learn sounds and where to find them.
Strings and the fretboard - why do we use tab? Well the banjo, slide guitar and ukulele are tuned to chords - so everything revolves around those chord shapes. Violins, Violas, Cellos etc are tuned to 4ths or 5ths so the pattern is repeated and discernable. The guitar is a bit of both and has the comfort of neither learning approach - so tab is used.
Snobbery about tab - tab predates notation (what did you think the ledger lines were for? they're strings originally for Lutes (tuned in 3rds)).
Music is about sounds and Pythagorus (father of modern mathematics) is the creator (or at least documenter) of the Western Musical scale - take a note, half it's frequency that's an octave below... increase the frequency by 50% and that's a fourth below the first note or a fifth above the second.. 50% of that notes and we're at thirds.
Everything in the world can be described in numbers and dimensions - lots and lots of them and it is rarely appropriate to do so - but try telling that to the robot men
1. Ref tab used for strings & fretboard: if your argument stands up keyboard players would also have a kind of tab, but they don't. tab was just an alternative to notation in the days when notation was not settled and "standardised" as it is now. as you said, it predates currently accepted notation. That doesn't make it better. Notation is not instrument-specific which is one of the reasons for it being superior.
2. leger lines aren't extra "strings". the stave (with its 5 lines) is only the visible part of a (conceptual) stave which extends upwards and downwards of what is restricted to 5 lines just for the convenience of printing. leger lines extend it in either direction when necessary
3. The theory about frequencies, doubling them for octave etc is OK in theory, but in practice doesn't work unless you stick to playing in one key which is why we use equal temperament as a convenient kludge so that we can combine notes in chords and change keys when we wish to.
Most things in this world can be described by numbers, as you say; I don't see anything wrong with that.
