All modern Fender WRHBs are not like the traditional ones, just standard humbuckers. What you heard is correct - the Mexican tele deluxe you tried will sound like it just has humbuckers in it because essentially it does!!
A few people now make good repros. I have one from Marc at Mojo but also Jamie at The Creamery and others do them too. Not cheap but they're not a simple design, comparatively.
Also note that 'proper' WRHBs are bigger than standard humbuckers, but people like Marc et al make standard-sized wide range pickups that will fit in your Jazzmaster with no modification.
Frankly, I really like them as a neck pickup, but prefer either the power and mids of a proper humbucker or the attack and bite of a true single coil in he bridge position, but horses for courses and all that!
yes, my one has an aluminium neck (which i highly recommend!)
As far as pickups go, it really depends on the kind of music you are playing...the wide-range would be cool to try out, but it will be different to humbuckers, and you may/may not like them...but worth a try if you're really wondering.
With mine, I have the neck pickups of lace sensors dirty heshers set sitting in there. I use to have those in my LP and they sounded very different than in the jazzmaster..."a jazzmaster will always sound like a jazzmaster"...which is something i read somewhere and within reason, its true. I think the jazzmaster will maintain the characteristics that make is sound different to most other gutiars.
as far as bridge and spacing...I also have the staytrem on mine, and i have no idea what spacing is on my pickups...I don't really think you should worry about that, its such an insignificant difference compared which pickups you end up going with.
I guess there's nothing "jumping" out at me hence the thoughts of changing the pickups.
I'm thinking right now that Seymour Duncans might be too obvious. So I did a bit of research on Lee Ranaldos guitar.
I am aware that the new wide range buckers are pretty much humbuckers, or am I wrong?
Are they fender's attempt at a P90?
