The correct way to intonate a 3 saddle Tele
I remember @icbm posting some pearls of wisdom back on the MR forum...but that's lost now. I'm planning on going from 9s to 10s on my Tele. It's a 'proper' 3 straight saddle set-up, non of these new fangled compensated ones.
  • ESBlondeESBlonde Frets: 3646
    It is just possible that you won't have any issues anyway, a slight adjustment maybe but don't read too much into it yet. I understand the desire to prepare for a possible issue but don't go looking for it. If you develop an issue then address it at that point.
    Very wise words
    You can always go to 6 saddles anyway. Just to please all the purists more than anything. :-P
  • graphtech compensated saddles...
    edited November 2013
    Once again I'm missing the power to facepalm!
     I just recall ICBM had some great tips on how best to make a compromise between the two strings on each saddle.
  • I'm stringing my tele from 11's to 10's tonight and it's a 3 saddle brass jobbie. Advice appreciated if it all goes tits up. With me at the helm, it probably will.
  • ICBMICBM Frets: 74396
    It was nothing more complicated than to set each saddle for the sharper of the two strings - ie the B, the G and the low E - since a sharp note is always more obvious and worse-sounding than a flat note, and you can compensate for a flat note with a slight increase in pressure or a tiny bend if you get good at it.
    Thanks
  • Yeh, what ICBM said (as usual!)
  • JAYJOJAYJO Frets: 1542
    ive recently restrung my tele. 3 brass saddles. As ive been playing unplugged recently ive notice a lot of buzz on the G string and The 1st E string maybe too low(action). If i alter the saddles height with the allen nuts will this affect the intonation. ie up and down as opposed to backwards and forwards. If so what do i do then ? Im using 10s  ps  I dont understand ICBMs explaination. cheers
    You might have to adjust the intonation, but probably not.
    Just set each saddle to the correct intonation for the string which sounds sharper. Many people set them to an average of the two, which gives you one slightly flat string and one slightly sharp, which you would think would be the best compromise… but it isn't, because the sharp string always sounds more jarring than the flat one (especially the G). So just set each saddle to make the sharp string in tune and let the other one take care of itself. Set the E/B saddle correct for the B, the G/D one for the G, and the A/E one for the E. Simples :).
    Thanks very much mate!
  • Or... buy some compensated brass saddles and fit them!
    260+ positive trading feedbacks: http://www.thefretboard.co.uk/discussion/57830/
    But then the mojo falls out of the guitar ;-)
  • jd0272jd0272 Frets: 3871
    Before I went compensated, I just flattened the G a bit. Worked fine, and wasn't really noticeable on the lower strings anyway. Had no complaints from fellow musos in gig crowds either.
    You'd get it back if they were compensated steel saddles ;).
    Not a fan of brass… [/heresy]
  • sorry I didnt read to the bottom of your post about the compensated saddles, and also read on the tele forum that becasue of what theyre made of (not metal) you may lose the ground on the strings if they dont come into contact with the bridge plate.
    Ive got a 52ri tele and when I took it to have a couple of the frets 'smoothed' the tech very slightly bent the screws that hold the brass 'saddles' (not even enough to notice theyre not straight) and ever since ive had near perfect intonation
  • bertiebertie Frets: 13587
    not in my hands
  • Zingy new strings fitted last night. Feels good with 10s on (I did have 9s on my Tele and my Strat and 10s on my Gibsons).
    I didn't have a lot of time so all I did was stick the new stings on and give it a bit of a play through my THR10. Sounded fine, but I'll check the intonation tonight (sounds like it's close though)
    I have the same guitar, do you have any issues with the neck/fretboard being sticky? Anyone else either?
  • when I first got the guitar it had a sticky neck but after using it its now smooth and fast.
