Song analysis: The Beatles - Something
  • I know what you mean. I've never quite grasped the whole theory thing, but some of it has gone in not through reading about it, or playing it but by doing both - I was shown it, it was explained and then I heard it and played it and it slowly started to sink in. There's a reasonable bit of theory I get, but can't do, like scales, for instance - I know what the modes are supposed to be about, but I can't crack them or remember them, if you know what I mean. So if there's a series of chords to solo over, I have to sit down and work it all out painstakingly and slowly. I can't just do it.
    I had the exact same experience with crosswords. I always wanted to be able to do cryptic crosswords, and I'd read three books on the subject and got precisely nowhere. Then I saw a documentary on BBC4 about it and bingo it clicked. I've been doing them every day ever since.
    If you must have sex with a frog, wear a condom. If you want the frog to have fun, rib it.
  • ClarkyClarky Frets: 3261
    there really is no substitute for having someone sit in front of you to explain something, demonstrate it, show you the possibilites..
    and if need be, take you by the hand and lead you on a voyage of discovery
  • Not that I want to discourage the idea of doing these analyses, which I think are great, but "Something" is also a song that always seemed to me very good at illustrating the limitations of analysis.
    For example, the bass part.  For me this is a masterpiece, one of thet greatest bass parts in all of rock and pop. I've seen more than one name bassist, the kind who could eat Macca for breakfast technically, admit that they can only dream of coming up with a part so original and perfect.  And yet, try to analyse it and everything that makes it great eludes description. It's basically arpeggios with some scalar connecting notes. It hints at the melody in places. Rhythmically it's a little random, slightly busier here, slightly sparser there - an obvious Jamerson influence, but this kind of randomness soon went out of fashion as bassists developed a preference for clarity, precision, repetition. But somehow a whole lot of stuff that analysis suggests is ordinary, even cliched, comes out as fresh and magical.
    There are other things we could discuss similarly - the descending basslines against triads sounds great, but they are also musical cliches.  Why are they so memorable in this song while failing to elevate other songs above the ordinary?  Why are the oh so simple guitar parts so memorable and effective? Why doesn't the ploddy and uninspired 'you're asking me' section totally ruin the song?
    The Beatles are weird in this regard. There used to be a school of thought that they were great songwriters but not so hot as instrumentalists or even singers. If that were true then given the many thousands of cover versions of their songs, many by artists who were great in their own right,  it should be easy to assemble a collection of Beatles covers that blow the originals out of the water.  But sit down and listen to a list of Beatles covers and you'll quickly realise that although there is the odd gem, remarkably few top the originals: for some reason no-one plays or sings Beatles songs as well as the Beatles. And again, how do you explain that?
  • fnptfnpt Frets: 750
    Clarky, would you be so kind as to analyse the solo as well, and maybe compare the choice of notes with the chords in the background?
    ____
    "You don't know what you've got till the whole thing's gone. The days are dark and the road is long."
    edited September 2013
    @blueingreen - everything has strengths and weaknesses yes? and some songs / pieces will offer more / less points of interest than others. So I guess you could argue "why analyse anything at all?"
    a reasonable enough question I guess...
    of course there are limitations to sensible things that you can find in some music to talk about..
    generally, classical music has more to offer from an analysis standpoint by virtue of the compositional process [think Sonata form, Baroque Suites, Concerti etc]..
    contemporary music most often does not contain anything close to the number of 'talking points' that you'd find in the 1st mvt of a Symphony...
    that said... even if a song, or a bit of a song can reveal something remotely interesting, then there is something to be gained for taking a detailed look at it..
    so.. Macca's bassline.. I reckon that'd be like trying to analyse a blues solo.. sounds to me like he is just playing what he feels sounds / fits the best and works best for the song... and I agree, it's very cool.. can you anayise any of that?? maybe there are some things of interest that are certainly worth a mention.. the first thing that springs to mind is the note density... the bass is consuming a lot of space.. I suspect that this is to prevent the song from 'plodding along' as it would if the bass were simply pumping root notes..
    You do seem to have ideas / opinions as to what it is that makes The Beetles different..
    Even talking about the more subjective elements is valid anaysis.. it don't all have to be hard facts..
    @fnpt - I'll take a look at the solo... generally solos in contempory music don't offer a great deal to talk about because the creative process is generally less 'composed' and more 'intuitively felt'. That said I'll see if I can find somethnig a little more interesting to say than "it sucks".. lmao
    ok... it's quite tough to find much of interest to say about that solo..
    it's not very big.. and not much happens..
    it's sparse and built around small licks.. lots of space.. minimal..
    it's mostly using C pentatonic licks so it's quite safe with the overriding C major / C mix tonality
    some of the licks are essentially similar fingerings in different positions
    this is an old 'trick' which gives a kind of "theme and variations" effect..
    so this sort of trick does make the solo sound a little more 'composed' rather than just throwing your entire lick vocabulary at it..
    the solo seems to be built from about three basic licks
    there are a few ways to approach a solo..
    - write one: a compositional approach
    pro's -- the solo can / should have more melodic content and contain more points of interest
    con's -- can be quite unexciting
    - free style: pure improv
    pro's -- can pull some serious fireworks out of the bag
    con's -- can sound like a series of preset licks or worse.. solo-ized exercises
    - a little of both
    this is my personal preferred approach..
    usually a composed entrance and exit with a few general contours
    but with enough scope to goof around..
    the solo in Something sounds to me to have been written after several takes / practice passes
    so it could have started life as a small improv and then settled into a set piece
    which funnily enough is how 90% of my solos [in mature songs] end up
  • BlueingreenBlueingreen Frets: 2612
    Clarky, I'm not suggesting analysis isn't worth doing.  It's worth doing insofar as it's useful, which it sometimes is.   But one of the things it's not terribly good is accounting for aesthetic value;  often a memorable melody shows no structural differences from a pedestrian one. The reason I posted wasn't to disagree with anyone but precisely because as a Beatles fan who at different points has learned the bass and guitar parts to this song I had had some thoughts in the past about how difficult it was to account for the things that made it work.
    The density point you made is basically the same one I make in talking about randomness.  The density (ie basically repetition of mainly arpeggiated notes) varies apparently randomly.  There's nothing obviously stylistically original in that - you can hear the same thing in players like Jamerson, Bob Babbit and Carol Kaye - and Macca does it himself elsewhere, perhaps most conspicuously in "Rain".
    @Blueingreen - ahh... I don't think I got what I'm thinking across too well in my previous comment to you.. hmm..
    I am actually agreeing with you that analysis has it's strengths and weaknesses..
    whilst some things are easy and clear [scales, form, key, specific compositional techniques etc] because they are solidly quantifiable, there are plenty of things that are not so clear...
    why does that lick with the phaser in Spirit of the Radio sound soooo hugely cool??
    erm... cos it does and cos it is, is about the best way I could answer that... lol..
    that said... it is possible and worthwhile looking at how a piece [or moment within it] makes you feel..
    I never lose sight of the fact that music is after all an "emotion delivery system"
    fun, sadness, triumph, hate, stupidity, fear, awe and so the list goes on..
    so it's also certainly a good thing to describe what it is, regarding what you're hearing, that makes you feel these emotions in terms of what the music is actually doing..
    there is a killer point about analysis that is often overlooked.. and this is that it's not unusual for the performer / composer to have not been considering all these 'things' that the analysis points out at the time.. and that it simply "seemed / felt like the right thing to do".. but that's ok.. the analysis isn't really trying to dive into the mind of the writer / performer.. more like, the analysis is trying to determine what it is that makes that moment so interesting / moving etc..
    the way I see it it, is that the analysis tries to makes some sort of sense of what you've heard so that you can learn from it and maybe take something inspiring and / or thought provoking away that has the potential to add new elements to your own writing..
    but like you say.. and rightly so.. all of this can only go so far..
    listening to Macca's bass part... it's actually almost like a solo throughout..
    why he chose to do this I have no idea.. but it does seem to add something very cool..
    I think it does add more variety to the song.. it certainly makes things sound a little more unpredictable...
    I think it's highly likely that he had been goofing around with the song and had come across some very cool little ideas and as the song progressed he was playing them all out.. kind of like 'improv on a theme / in and around some ideas"..
    maybe he was trying to avoid being repetitive to keep things interesting [but who for, the listener or himself]..
    I reckon it was a bit of all of the above.. he had some ideas pre-worked out from the point of view of the approach to the song, and then kinda jammed with it when recording.. hence that unpredictable quality..
    I think it's well worth considering the time in The Beatles career when this was written.. this was a time when they were getting very experimental.. so was he simply trying to be a little different?? when most bassists at that time in that style would happily pump away on the roots... strangely, the bass is actually to most active instrument in this song.. but because it's in a different register to the vocal, there is never a conflict between them..
    I chose Something for good reason....
    for what is on the surface and nice simple song... deep down inside it there is some very cool stuff happening.. and some very shrewd song writing going on...
    which of course offers plenty to talk about...
  • close2uclose2u Frets: 997
    isolated bass & drums if it helps
    http://www.youtube.com/watch?v=1VICLxf5JwA
    wow... listening to that was soooo revealing...
    Given your great analysis so far I'm interested to read what further thoughts have been revealed to you ... and I'm not a bassist
  • Thanks for the in-depth analysis, Clarky, very interesting. :)
    The sum being greater than the parts?
  • @Clarky
    I've been learning this stuff and trying to analyse the song myself. You've put some really great information in this thread and it's been loads of use. I really appreciate the time you've taken, thank you!
    haa… no probs matey...
  • Are we going to have another song analysis thread? May I suggest another Beatles number?
    why not...
    what do you have in mind?
  • Not contributing, but great idea!
    Panic Attack - Dream Theatre ;-)
    Reading all this, despite not being a fan of the Beatles, I might learn a couple of songs to get a feel for different chord progressions.  I'm more of a riff guy, though, than specific harmony.
  • I quite like the idea of Dear Prudence, or any of the White album. Could be worth starting a new thread and then we could archive them like chord of the week...
  • BasherBasher Frets: 1206
    edited January 2014
  • Necro-post!
    I had a look at this solo today so may as well park it here...
    PDF available from link in sig.
