I've got water trapped in my ear
holnrewholnrew Frets: 8207
Had a shower about half an hour ago and my ear is starting to ache a little. I put a bit rolled up kitchen towel just inside hoping it would soak it up but that didn't work.
Any tips?
My V key is broken
«134
  • DiscoStuDiscoStu Frets: 5737
    Hammer. Cold chisel.
  • guitars4youguitars4you Frets: 15430
    My daughter had similar on holiday - paracetamol and in the morning a bullet size lump of wax on her pillow - fine after
  • sinbaadisinbaadi Frets: 1424
    Cotton bud, ear pointed downward.  Wiggle cotton bud around a bit to let the water run down.
  • holnrewholnrew Frets: 8207
    I hope this happens to me.
    I'll try the cotton bud
    My V key is broken
    wax has swelled up with the water....all the medical advice is to not put anything smaller than your elbow into your ear....you can cause more damage with a cotton bud so just give it time and use some drops to soften it.
  • HootsmonHootsmon Frets: 16315
    edited July 2016
    try leanin' over tae one side and tilt your head,tilt your head over tae the phone, and from this position, phone your Doctor
    tae be or not tae be
    6reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • SporkySporky Frets: 30213
    You shouldn't put anything smaller than your elbow into your ear.
  • ennspekennspek Frets: 1626
    Olive oil.
  • jaytmonjaytmon Frets: 168
    I bought some ear drops recently that came with a rubber syringe type thing (looks like a mini turkey baster) for 'gently' blasting out softened wax. Something that could do that could help.
    Alternatively shake your head furiously to the affected side like a demented chicken trying to peck at seeds with its ear....
  • ToneControlToneControl Frets: 12256
    unless you are very careful, cotton buds cause harm
    go to a pharmacy, and ask them for something that shifts excess wax
    otherwise it's imflamed, GP  tomorrow
  • earwighoneyearwighoney Frets: 3592
    Any tips?
    Leave it be.  It should sort itself out by the following day or so.
    I've had lots of ear related problems over the last 10 years or so and a trip to the GP is most likely to result in having antibiotics prescribed which don't really do much (even if you have an infection, which you don't)
  • vizviz Frets: 11041
    Don't put cotton buds in your ear.
  • Hertz32Hertz32 Frets: 2248
    Put your elbow in your ear.
    'Awibble'
    4reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • richardhomerrichardhomer Frets: 25006
    Otex ear drops....
    And as others have said - don't poke about with cotton buds or anything else.
  • JezWyndJezWynd Frets: 6318
    I had the same very recently. Tried Otex for a few days without any improvement. Then tried olive oil for couple of days and cured it. Use warm olive oil and put a couple of ml in your ear three or four times a day. After two or three days irrigate your ear or get GP nurse to do it for you.
  • lloydlloyd Frets: 5774
    Listen to some Elbow, with your ears.
    Manchester based original indie band Random White:
    https://www.facebook.com/RandomWhite
    https://twitter.com/randomwhite1
    8reaction image LOL 0reaction image Wow! 0reaction image Wisdom
  • HippoPeteHippoPete Frets: 136
    edited July 2016
    Something that works for me is to use Olive oil or Otex drops then after a while massage, the soft bit of your ear nearest front. You may find that that it feels like it's "almost" popping or that it pops and then goes back to blocked. Do it regularly and it will stay popped, might be a day or two though. I have waxy ears and learnt to my frustration over the years that no matter how tempted you are, don't use the ear buds, it's solid advice above. And go to the docs if it's actually hurting.
    They don't want your name, they just want your number.
  • octatonicoctatonic Frets: 34318
    If this was true then the thousands and thousands of people that use earplugs and IEM's would be able to get compensation for hearing loss.
    Only from themselves.
  • GassageGassage Frets: 31591
    Tap on the head.
