Yamaha APX500, no sound through amp?
I've never played this through an amp before,  so tonight I thought Id play it through my Vox Cambridge 30, no sound, nothing.
The only thing I can think of is the battery in the Yamaha is flat, is this why I'm getting no sound from the amp? Is the Yamaha somehow pre-amped and needs a battery?
  • ICBMICBM Frets: 72770
    Yes :).
    Hopefully it's just that. Which version is it, the one with a normal preamp unit in the side, or with the recessed knobs that push in and out?
  • robgilmorobgilmo Frets: 3657
    I dont think the jobs push in or out, its got a volume, 3 band eq and a tuner.
    Oh, and a slide switch tone thingy.
    That's good - if it isn't the battery and there is a preamp fault, the older push-in knob type can no longer be easily (or often at all) repaired because Yamaha have run out of replacement PCBs for them.
  • I think is the battery sure.
    New battery sorted it guys, Ive never played an acoustic through an amp before, this has put a whole new kettle of fish on the hob, I'm loving this!
