I've owned Waves Gold for a few years, the only plugins I still use from it are H delay and L1. Comparatively that makes it an expensive purchase. I've got several other Waves plugs but they were all bought individually. The next level bundle upgrade doesn't interest me at all, ad after that it gets super expensive, so waiting for the sale rotation is a better plan.
Which FF plugs did you get @PolarityMan and how are you finding them?
Only used them for about half an hour as bought it a couple of weeks ago then immediately went on holiday but Ive wanted pro-q 2 in particular for ageeeeeeees.
Not sure Ill use MB much but C2 and L look pretty decent too.
Public Service Announcement: Eventide released a new delay plugin called Ultratap.
It is $49 until September.
I've had it for a few hours and it is pretty awesome.
I'm a huge fan of Eventide plugins and they bless you with two authorisations per purchase, so you can have your main Daw and a laptop authorised without having to swap iLoks.
I would avoid the Waves subscription. It is $1500 a year for Mercury which is crazy.
I've had Waves Mercury for quite a long time- well before other companies were on the market- virtually every plugin that Waves do is done better by someone else.
Exceptions are Dorrough metering, Brauer Motion and Restoration bundle.
UAD are doing some awesome things- the Massive Passive, SSL, Chandler Curve Bender, EL Fatso, Thermonic Culture Vulture, Shadow Hills Mastering Comp are all incredibly close to the hardware they are replicating.
Also check out Expoential Audio- their Excalibur plugin is the best delay plugin I've heard. I use it on everything.
Football is rubbish.
Pro-MB is very useful if you do come across something where MB compression is needed, e.g. Low end boom in palm muted passive guitars.
I also find I use it on certain vocals that use a lot of range and dynamics, as static EQ and broadband compression don't always deal with a singer going from warm low notes to yelled high notes. I sometimes also use it in sidechain on slower songs that need a relatively big bass, but also a relatively big kick to cut through. On faster songs with lots of kick hits I've found it's better to separate more clearly with EQ.
Pro C2's reduction limit mode (prob wrong term) is also mega useful if you want a consistent amount of gain reduction - again sidechain might be a reason to do this. It's got lots of different modes and a very easy to use GUI.
Have a listen to these:
This is the part without Ultratap instantiated: http://www.jamesrichmond.com/moved/ultratap/Stabs_no_ultratap.mp3
This is the part with it in there: http://www.jamesrichmond.com/moved/ultratap/Stabs_with_ultratap.mp3
Here it is in the context of the track: http://www.jamesrichmond.com/moved/ultratap/ALL_Stabs_with_ultratap.mp3
I spent ages demoing the ones I absolutely had to have and then bought them as part of the summer sale.
They were about £1200 for the lot and would have cost £3500 outside the sale.
The Neve 33609 is awesome sauce.
Just on this point - the Studio Classics Collection Contains the SSL bundle, API bundle, and V Series and is currently on sale for cheaper than the upgrade to the SSL collection, or the SSL Collection on its own.
The Abbey Roads collection is also on sale https://www.audiodeluxe.com/products/waves-abbey-road-collection
10% off via code from https://www.retailmenot.com/view/waves.com?c=7666283 seems to work at AD
http://www.waves.com/plugins/ssl-g-channel
It is a really novel approach and I believe it works.
