have you held one?
Instagram
wind a pickup under fairly low tension, leave it unpotted, remove the strings entirely ... then shout into the pickup ... it will work as a microphone ... a quiet one ... but it will amplify your voice.
Does wood influence how a guitar sounds in a meaningful way? Hmmm.
What if I record three guitars straight into a desk. No pedals, no amp. I have £100 that says that you can't say what wood is used for the bodies on these three guitars.I'll give you the benefit of the doubt - get two right and I'll pay up. Get two or more wrong, you pay me.
Any takers?
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
You've quoted some prices that you, as a small builder, pay for and you are small fry compared to a corporation, as am I.
You are looking this through the tiny lens of your own experience and whilst that might be true for you- the rest of the industry, which is about a billion times bigger than you, doesn't work that way.
Large corporations buy wood in bulk- they pay much less for 'tone woods' than you or I do.
They leverage the wood suppliers and buy in bulk bringing the cost of the wood down much lower than you or I can dream of paying.
If you compare the price of a £2000 guitar to a £500 guitar the difference between cost of the raw wood will be much less than the difference of cost of the final guitars.
I know this for a fact after having studied lutherie at university and also having spoken with some of the people at several multinational builders as part of doing my dissertation.
I'm surprised you don't already know this.
Frankly, I think I'm owed an apology.
It's emotive far and above it's factual content ...
Lets all take a healthy swig of calm the fuck down ... and realise it's only a forum.
I have just tried my acoustic and the soundboard seems to resonate equally strongly whatever note I play. No surprise really given that the soundboard of an acoustic is carefully designed to be as neutral as possible in its response, with no 'wolf tones' or dead spots.
However, on picking up one my of my electrics the resonance of the body seems to be nowhere near as consistent. For example, especially on the higher strings, certain notes note certainly do cause the neck to resonate noticeably. However, a note a semi-tone higher might not be 'felt' at all. Also, the body only seems to resonate noticeably when playing certain bass notes.
This suggests to me that, if resonance was an important factor in the tone of a solid body electric guitar, a solid body instruments would be likely to have a very unbalanced sound, with some notes being much louder and possibly having a different tonal quality to notes only a semi-tone away on the same string. In reality I don't find this, indicating that the resonant qualities of the neck and body make very little contribution to the sound and (as the research I linked to earlier notes) such resonance only being significant in so much as it can reduce the sustain of certain notes.
For every action there is an equal and opposite reaction - Isaac Newton
When the string is plucked it puts a force on the boday, and the body puts a force on the string. Energy will be transferred to the body.
This will result in vibration of the body, and very small movement of the pickups, which will have some effect on the signal the pickup generates.
I suspect that the bigger effect is that the body damps certain frequencies, and then the vibrations of the body feedback into the strings, which is picked up by the pickup.
It's already been said, but if it was only the string and the pickups without any effect from the body, a 335 with 57 Classics would sound the same as an SG with 57 Classics, which would also sound the same as a Les Paul with 57 Classics. That is definitely not the case. They all sound different. None of them sounds like a Strat - there is a family resemblance if you like, but while the differences aren't huge, they definitely exist, and are noticeable.
Materials play a part of the sound but only so much construction I feel makes the main difference.
Hence a steel Trussart tele sounds like a tele!
Anybody remember Modulus Graphite guitars not wood but still sounded like a tele.
hands make the biggest difference so just play them.
Inevitably in my experience the players that refuse to accept that tonewood makes a difference play HB guitars through higher gain amps and the ones that argue that tonewood does make a difference generally play country or blues with a single coil through a clean amp, which tells you why there's always a heated debate about it.
Very simply, an acoustic is totally unprocessed and the further you process the signal, ending with a high output HB with a floyd, the less the wood matters (IMO).
