I would also be careful about the '100W' rating - that's electrical power, not a cranked 100W amp which can put out up to double that.
I have built a number of load boxes up to 0.5kW continuous rating and there are few wrinkles. Give me a PM if you like and I might save you a bit of time, cash or burnt pinkies (or even worse? Something of 'er's indoors!)
Dave.
I've been looking around the net at different L-pad schems, trying to work out why I need big resistors rather than just the actual L-pad when I only want to build a simple 8 ohm jobbie for my 50w Marshall (no bypass switch per ICBM), but when I get my head around it I may well be in touch, cheers!
Added to that, a fully distorted guitar amp will put out much more than its rated clean power, usually up to about twice, although probably not quite continuously - so really, you can't use a "100W" (ie 25W) L-Pad with much more than about a 15W amp safely since it can be putting out around a continuous 25W on average.
Hence to build a 100W attenuator you need three 25W resistors and and a "100W" L-Pad, and even then it will be close to the limit with a 60W amp as Almach has discovered, even using 50W resistors (although not very heatsinked).
This is why commercial attenuators are big, heavy and expensive - there really isn't an easy way around dissipating this sort of power, at least not if you want to have the output controllable.
This would be just an experiment, but at the same time I have zero interest in bollixing my amp
I recently acquired a Tweed Champ style amp built by @4114Effects that sounds sweet and is very responsive to pick attack and to the volume pot but obviously benefits from being turned up a little more than I can justify at home. With my previous amp (Blues jr.) I'd just stick a pedal in front of it for hair or drive but with the new one this feels like taking away the magic.
So what would I need to build to get the sound of this little 5w amp at 5-7 on the dial, but with the volume it has on 2?
I haven't built pedals before but do my own guitar wiring so I assume I should be ok on that front.
Those in a simple metal enclosure with two jacks should work fine.
If the amp is an 8-ohm output then the L-pad alone will be enough.
Edited to add: I suppose this: http://www.theguitarmagazine.com/diy/diy-workshop-build-your-own-attenuator/ takes care of the wiring diagram and instructions
