Squier telecasters
TTBZTTBZ Frets: 2957
edited November 2017 in Guitar
I've been thinking about it for ages and I reckon now is maybe the time for me to give a tele a go. I can't afford a fancy one but to me part of the appeal of a tele is it's cheap, rough and ready and not posh. I've played an Affinity tele and really liked it but had these concerns:
- pickguard. First thing I'll want to do is change the pickguard but have heard it's not a standard fender size? Is it a pain to find a black one to fit without going custom?
- narrower nut. The narrow neck on this feels really nice to me but is it a problem to find replacements? Or will any good luthier have no problem sourcing or making a nut to fit?
- thinner body. Does it really affect tone or sustain when plugged in that couldn't be compensated for with pickups?
- top loading bridge. As above re the body, is there really much noticeable benefit to string thru? Suppose I could always drill it in the future.
Or is there any real merit to saving a bit longer and getting a used CV 50s, or a used Fender MIM? As I said I've played an Affinity and liked it but that wasn't a long term test. I have a set of hipshot tuners I can drop straight in so that's one cheap guitar "problem" fixed. I didn't play it plugged in but had kinda factored in getting some Oil City pickups in it at some point unless the stock ones are any good.
«134
  • Instead of getting something that you would immediately change a bunch of things on I would try to hold out for a CV. They’re great guitars
  • p90foolp90fool Frets: 31963
    If you're just Telecurious the Affinity is fine.
    The neck pickup is a bit lifeless (unless you remove the cover) but the bridge pickup is great fun and very authentic sounding in an early 1960s kind of way.
  • stimpsonslostsonstimpsonslostson Frets: 5422
    This.
    Affinitys/Affinities/Affinitii are fine guitars "as is" but there is a point where Triggers Broom sets in.
    Judging by your comments I'd be looking at the CV50s or a MIM- a good, ready made guitar that the majority of future upgrades will drop into. Failing that, have you considered a Partscaster?
    Tele Partscasters are easy to put together and you can get the spec you want from the outset (& mod it as your tastes change).
    IIRC @lonestar ;;; has a beautiful blue tele body for sale, get a neck, hardware and Robert's your mothers brother.
    If you're thinking OilCity pickups, it's worth considering a harness from Ash too- excellent quality & a real improvement on virtually anything I've seen fitted in a factory.
    Regarding the toploading bridge- some people prefer them. I THINK ICBM falls into this camp- lower string tension over the bridge = more twang?
  • impmannimpmann Frets: 12723
    TBH, I'd suggest saving the money up and buying something better than the Affinity. The CV is a country mile better (and closer to a real Tele - in fact, it *is* a real Tele) and by the time you've upgraded this and changed that, you'll end up spending a load of money on something that will always be a poor man's Tele.
    Other guitars to consider - the Vintage Tele copies are superb and come up really cheap. There was one in the Kettering Crack Converters recently for £85. Tokai chinese ones are OK and cheap - although I'm not a fan of the pickups, the necks are OK. Finally the Harley Benton (Thomann) guitars - ok, the headstock is eaten up with the uglies but they are generally fine guitars... although some can be a touch heavy in weight.
    Or as mentioned above, build something or buy a Partcaster - buy carefully and you can end up with a guitar that is greater than the sum of its parts.
    Classic vibe!
  • JezWyndJezWynd Frets: 6178
    I used an Affinity for a while and found it fine. The neck was quite playable and I was able to replace the pickguard with an old Fender single ply I had lying around very easily. The only problem I experienced was with the bridge saddle screws coming loose and causing rogue vibrations but once I'd sussed the problem it was easily fixed. You'll want to upgrade eventually but as a toe in the water they're a good buy.
  • I have a cv and it is fantastic, it has killed my tele gas once and for all.
  • TTBZTTBZ Frets: 2957
    Had considered the parts route but since at this stage I'm more "telecurious" as p90fool says I'm concerned I might end up not getting on with it then losing a load of money if I want to sell it. That's certainly been the case in the past and maybe this time I should learn from my mistakes!
    I think you're all confirming what I knew all along though, that I'd get an Affinity and spend a fortune doing it up, only to have spent the same as I would have on a CV!
    Wish I could say this want true but I don't think I could ever be happy with having a Squier logo on the headstock
    Why not? They're clearly great guitars given how many great reviews they get.
  • I've had an Affinity for about 10 years and love it, as is.  I was going to swap out the white pickguard but ran into the already mentioned incompatible issue and decided to leave it alone.
    Gives you a good excuse to play badly tho :blush:
  • mikeyrob73mikeyrob73 Frets: 4694
    CV all day long, i sold my Baja because i preferred the neck on the CV, couldnt care less what it says on the headstock, its a damn fine guitar
  • darthed1981darthed1981 Frets: 12413
    Even the Squier Bullets are surprisingly good, the Classic Vibes are easily a match for Mexican Fenders, in fact I chose my CV tele over a Mexican Tele because I preferred the neck, though personally I found the pickups on the Mexi possibly slightly better, it is very YMMV.
    The CV teles do have vintage split tuners which I sodding hate, I restrung mine the other week though and managed it just fine :)
  • My only bugbear with the CV is the gloopy finish on the neck (both the back and the fretboard). Other than that I really liked it.
    The best neck I've ever played was on a Squier Trohman tele. It was phenomenal... I'd love to buy one of those, but they've dropped off the face of the earth.
    Squier is cooler than Fender in a garagey sort of way.  Doing the festival rounds last year I was surprised how many of the younger, cooler bands were playing Squiers.  Only the Dadrock bands had expensive guitars, the cutting-edge stuff was being played on cheapies like Squiers.
    0reaction image LOL 1reaction image Wow! 4reaction image Wisdom
  • ModellistaModellista Frets: 2046
    As long as you don't pour any money into it in "upgrades", the Affinity is a perfectly decent starting point.  When funds allow, sell it and buy something better.  I would go something like Affinity Squier -> Pro Tone Squier -> Jap Fender -> US vintage reissue (£0.1k, £0.3k, £0.6k, £1k).
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8825
    Thanks for the mention @stimpsonslostson ;
    Yip I have this unloaded body for sale :)
    https://i.imgur.com/bDbYKpi.jpg
    Expensive fenders always baffle me tbh. No matter how expensive they are they always feel like 2 bits of wood bolted together rather than a "nice" instrument.
    As opposed to Gibson gluing several lumps together, often in the 'wrong' places, using too much glue and then not finishing it properly afterwards? ;-)
