I'm aware of the obvious ones but just wondering if anyone has any pearls of wisdom in regards to this. Or knows of any products available on the UK market that are available to order, and that they'd recommend.
All the decent rubber boot type platform things don't seem to be stocked in the UK, and i don't fancy paying a tenner postage from Thomann, on a 20 quid piece of rubber.
The 'Stagetrix' wah fastener' things have been discontinued it seems.
There's an online retailer that's selling shaped pieces of wood with trunk mat attached to either side and charging 20 quid plus postage for them. Maybe i'm in the wrong profession..
I can't really use the figure of 8 washer type things and screw them in as i don't fancy drilling the board out if i can help it.
Surely this is a very common problem. Was fine on a pedaltrain type board as the protruding parts just sat between the slats. But at the moment i have a T Rex tonetrunk and need the wah to mount securely to a flat surface.
Any idea's? before i drop £30 (a tenner of which for postage), on a piece of rubber with four holes in it..
Thanks guys.
''i've not seen a reaction like that in here since George Best got kicked out for glassing a bouncer''
Which reminds me I need to redo this with much thinner "wood" (from a mini crate of satsumas we bought at Christmas), dual lock adds a lot of height all by itself
You can buy them in different sizes for different wah designs etc
Cheers!
https://www.gak.co.uk/en/ews-wah-board-special-vox/121208
Only ones i found were on Thomann, with a tenner delivery.
Cheers mate!
