soundcloud.com/thecolourbox-1
I doubt a valve amp is going to give you what you want either, to be honest - direct recording is not what they're best at. If you're really going to use it only for recording and not as a 'live' amp, even at home, you'd be better off with a dedicated recording preamp most likely.
My producer commented that the tone was outstanding and we couldn't hear any difference between that setup and when we recorded miked up a year previous to that on a band project.
I did the same with my carvin legacy and that sounded fantastic too.
The H&K TubeMeister 36 show demo -
I would advise against that. The ID 15 and 30 combos do not provide a speaker output jack and I would assume that this is because the power amplifiers are not protected to the same extent as the 60 and 100watt amps which of course do provide speaker jacks. They are primarily "practice" amps not designed for knock about stage work IMHO.
Then the PA is a class D switching design and although it has been tested to satisfy all the EM regulations they might well still put out enough switching noise to bother an AI input. Also 30W into 4Ohms is over 30volts peak to peak, that could blow input protection diodes and not everything HAS protection diodes! In general I do not advise connecting PA outs to inputs unless properly loaded and attenuated. The latter will also cover the noise issue that ICBM raised.
According to the Blackstar handbook the emulated output can be changed in software to deliver "left processed, right dry" The right output will be available from the ring connection of a stereo jack lead.
As ever, always best to talk to the organ grinder!
Dave.
If you have the Laney preamp, why not just try it?!
A valve amp won't help - as far as I know, you don't really get ac30 type amps with emulated out anyway, and even if you used a box to do it, it's a very large, expensive solution to a problem that probably won't give better results.
Hank Marvin is known for his ac30 clean tone. Getting a two rock will sound great for a standard fender clean tone, but you'll need to play out loud, not with headphones, and most emulated boxes will make it sound... Well, probably just like a tech 21.
They do a fender voiced one, if that's your bag, but unless you're planning on using the speaker (and truthfully, at a reasonable volume, though not necessarily *loud*) I'd say a dedicated box for the job is better.
The kemper or axe fx ii might give you the best of both - you get to empty your wallet on a treat (and why not?) plus they are excellent for DI recording.
No! No! I did not mean you IC!
I was referring to myself! I did not get that involved during my short, second term at B's with the IDs to any great extent.
I simply took the view that most small, low power sstate G amps do not provide a speaker jack because people would fork 'em!
I have not seriously abused the 15/30 amps. I HAVE done unspeakable things to the 60/100 PAs and they lived.
Dave.
You have some wonderful guitars, and you want to hear them at their best, considering all circumstances. I'd say a kemper (plus a professionally modeled set of amps) would probably suit you well. You'd get great tone through pa speakers if you did want to go loud, but you can use it straight to a desk or with headphones, and it sounds amazing when used right.
