LJ20 Help Please!
1235»
  • WazmeisterWazmeister Frets: 9676
    Ok, I’ll be the one to say it...
    A month wait mate ? Wow.
  • JerkMoansJerkMoans Frets: 8831
    Going beyond the near-sexual thrill of delayed gratification, to an almost Zen-like state of inactivity. It’s probably good for me.
    Inactivist Lefty Lawyer
  • DrCorneliusDrCornelius Frets: 7307
    Tantric amp repair
    Tantric amp repair
    JerkMoans said:
    Tantric amp repair
    Sorry which one of the Mr Men is that ?
    JerkMoans said:
    Tantric amp repair
    Mr Om
    Great reply... LOL awarded :)
  • hoopshoops Frets: 227
    Still no news. What's happening?
  • SunDevilSunDevil Frets: 511
    It’s going to come back as a Silverface at this rate ;-)
    Got it back ten days ago but have been so crazy busy haven't yet had the chance to road test the thing.  The good news is that it's all been upgraded to 2018 LJ20 specs so I'm expecting fine, fine things from this bad boy.
    ...if the demands of selling my surplus labour ever let up...
  • jpfampsjpfamps Frets: 2738
    BBBlues said:
    DJH83004 said:
    BBBlues said:
    I think I'd go for one without modules too. Isn't the VAC just a resistor anyway?
    No it’s a power mosfet from memory
    Ah, a voltage controlled variable resistor?
    More likely some form of variable voltage regulator.
    I variable resistor (or equivalent) could be used, but it will increase the impedance of the power supply as you turn the power down, which is not ideal.
    Lebarque said:
    The problem with using a reverb pedal in front is that the amount of reverb goes up and down as you use you guitar volume knob to control gain: less with your clean sound and more with dirty (the opposite to how I want it!) Any solutions@StuartMac ?
    I was therefore considering getting the reverb module fitted too, but maybe won't bother, if it's not stellar.
    Most amps will have this problem to some degree, as the signal sent to the reverb tank varies with the guitar signal (and indeed volume settings on the amp).
    Hammond had an ingenious gain reduction circuit in their reverb circuit (an incandescent bulb!), but I've not seen this circuit in a guitar amp.
    Perhaps in most amps the tank is driven hard enough at modest volumes that variations in drive don't have that great an effect; reverb tanks don't generate much more reverb once the input is driven beyond a certain point, almost like some form of signal limiting.
