Overdrives that also work into clean amps
  • ICBMICBM Frets: 72839
    Rat. You just need the filter set a bit higher into a clean amp.
  • monquixotemonquixote Frets: 17733
    I like RAT's into clean amps.
    Not as fond into a dirty one.
    I like the Blackstar HT-Dual into a clean amp.
    I can't imagine it working into a dirty amp though?
    It does sound good into both and an obvious advantage is that you can have it setting one channel for your clean amp and one for your dirty.
    As an 'uncool' outsider the Hardwire CM-2 was pretty impressive into both,  fairly flexible and probably only £40-£50 s/h to try.
    Would quite like to try a CM-2
    I've had an SC-2 in the past and that was decent.
    Nah it works okay. Just gotta watch the gain levels when you do it that way.
  • octatonicoctatonic Frets: 33882
    Emma Stinkbug.
    I don't know why this pedal doesn't get more press.
  • ZVex Distortron would get my vote as well. I used to run it into an AC30 that was wound up to just below breakup so I was getting a mix of the pedal gain and the amp being being pushed over the edge. Lovely.
    I love my Bognor Blue but I'm not sure how it would sound into a driven amp. What I do like about it is the three band EQ and plenty of toggle switches that make a noticeable difference. It means you have to spend more time with it than a regular vol/tone/gain pedal but it's worth it. Plus the lead boost is great.
    I'm actually very seriously considering the Bognor Blue on the classifieds.
    What about the V1 Marshall Guv'nor in the classifieds?
    They sound great.
    Since realising that they had a loop into which I could put a delay I'm quite enamoured of the Mk1 Guv'nor
  • EricTheWearyEricTheWeary Frets: 16304
    oh, do they ? I was thinking not enough pedals have their own loop. I think some of the Amptweaker ones do but I couldn't think of any others.
    edited August 2013
    And the EQ. I don't like the HT-Dist I have (basically channel 2 of the Dual) into a dirty amp, or at least not with anything like the same EQ that I would want into a clean amp, but I may be using much less mids than you do. You can get away with it better if you boost the mids and cut treble and bass, but I still don't really like it... too muddy. The Mesa V-Twin suffers from exactly the same problem - I'd never consider them overdrive pedals, they're preamps.
  • I'm actually very seriously considering the Bognor Blue on the classifieds.
    If by some stretch I make it to the East Anglian meet up next month I'll bring my board so you can try it. It's pretty unlikely I'll make it though. :(
  • mike257mike257 Frets: 374
    The Big Bite overdrive is great for this. Used to run it into a super clean Carlsbro 50 Top for slightly driven and then lead boost tones. Sounds just as good into the Genz Benz Black Pearl when I stack it with the Pearl's on board boost. Well worth a look and an awesome UK based builder too!
  • MajorscaleMajorscale Frets: 1565
    My absolute favourite for both situations is the Honeybee...
  • benmurray85benmurray85 Frets: 1397
    I love the trex moeller. Clean channel gives lovely light to mid gains with tonnes of clarity and into an OD channel you get pretty much what you'd expect
    How very rock and roll
  • FazerFazer Frets: 468
    fairfield circuitry barbershop
  • Dave_McDave_Mc Frets: 2386
    I haven't tried it, but as far as i'm aware a signa drive is basically a tweaked tubescreamer, so if you don't like how a tubescreamer sounds into a clean amp...
