Besides Coda, what shops routinely weigh their individual instruments?
To cut a long story short I've had a bit of a rubbish year with shoulder and elbow injuries and the reality is that lighter guitars (and good straps) are the difference between me enjoying playing or being in discomfort. I am still having physio and remain confident I'll make a complete recovery, but going forward I want stick to lighter instruments. So potentially two of my instruments are likely to be sold or traded in the coming months as and when I find suitable replacements.
Thanks
Normally on 'box shifting' items they will use a generic photo, so no individual pics, check-up, set-up - Just a label on the box for delivery - Amazon style
Appreciate nobody is going to be weighing every individual low end guitar, but with things like that I'd just go to a shop and try a bunch.
Flying Vs I’m not sure about, if I wanted a ‘shape’ guitar I’d go explorer but I’m not so sure on the typical weight.
SG geometry might not be helpful. Because the neck joins the body much higher up, it puts your left hand further away for open position chords. I ended up selling my SG.
If you want that style of guitar, some of the all mahogany PRS like the Mira might be a better bet. If you can find a light one, some of their S2 or SE Singlecuts can be quite light.
I don't know what you are playing at the moment, but if it's a Les Paul, then an ES Les Paul is well worth a look. It doesn't have the spiky sound of some of the all mahogany guitars like an SG.
If you are into Fender style guitars then you can find Teles and Strats that are quite light - Teles more so than Strats though. The bridge and trem assembly on the Strat add a bit of weight.
Charlie Chandler’s CGX sometimes include weights in their online listings.
I've not played an SG in a few years so it is a fair point I would need to play one on a strap for a while and see what it felt like.
I do like Fenders and am covered for a Strat and Tele right now.
On paper what I'd like is a sub 9lb, ideally 8.5lb Les Paul, but I'd consider other instruments as well, Singlecut PRS and possibly a CU22/Standard 22. Basically something 24.75"-25" scale and dual humbuckers, more traditional kind of solidbody vibe vs metal as I have metal stuff covered.
Whatever I purchase will be getting an evertune bridge. There really isn't much/any choice in the EU for off the shelf traditional type guitars with evertunes, though you can order Les Paul Studios with Evertunes direct from the company.
I'm very happy with my current evertune guitars, and initially thought about getting one fitted to either my Les Paul or Singlecut but given the injuries I've had this year I've decided much as I think they're incredible sounding instruments I'd rather just play something less heavy... they're both sat in cases and I mainly play my MIM Tele with evertune and my LTD MH1000ET (super strat with evertune).
Well, I'm a lot heavier than any of my guitars.
It's an injury thing and the way I feel about guitars is I'd rather have slightly less than the ideal guitar, and be able to play it. Even though I think my Les Paul sounds monstrous, if I can't play it stood up it's kind of pointless and that's why it's been sat in its case for months and I've been playing a pointy LTD instead.
Cheers. Just one of those things!
Ideally something along the lines of a lightweight Les Paul or PRS 22 fret.
I hear such issues with many players, especially Gibson based - Granted you'll find a lighter SG, but then is it the guitar you like/want - You'll find the odd chambered, or semi hollow LP based guitar - same question - I heard of a guy a few years ago with such an issue ref back/shoulder - He had an 80's LP - He had a repairer leave the front as is, so it looked correct, but turn it over and it was /carved out, to remove most of the wood from the body - Other than the area around the pick-ups + bridge and tailpiece, it was totally devoid of wood - I only saw the pics, so how it sounded I don't know, but obviously some compromise required, but he still had a guitar that looked like an LP with the neck he liked and had played for years
I would not do that to a regular LP, but if needs must, then maybe a Tokai converted or an LP Studio might be an option - Just a thought
My Les Paul is weight relieved already and still weighs over 11lb, I’m concerned there isn’t enough that could be removed from it to make it a reasonable weight.
A Studio would be on the radar for sure. That’s part of what started my whole journey with evertune bridges. The last Blink 182 album was tracked on a modded LP Studio with an evertune bridge, and that’s a band that would easily have access to all kinds of instruments.
Otherwise I believe the les Paul axcess was pretty light too.
