BCD - Where is it?
    @BloodEagle - we do care really ;)
  • droflufdrofluf Frets: 3716
    And as if by magic!
    Thanks!
    I cant either- Rabbit hole?
    Done
  • BloodEagleBloodEagle Frets: 5320
    Very kind of you - thanks
    No worries. If there’s anyone else then shout up.
  • Revolting1Revolting1 Frets: 295
    Cheers
    When logic and proportion
    edited June 2019
    Right - Ive seen enough. Please disable my access again
  • munckeemunckee Frets: 12403
    You can't unsee it, only way is to poke your eyes out with a stick so you can never see it again.
    That doesn’t work...
  • DLMDLM Frets: 2513
    Just to be clear: we are still talking about FilthyPhil's 3,000 post naked run selfie on intermusic, right?
  • RolandRoland Frets: 8731
    Nope. We’re talking about the placed where we move the threads that aren't worth moderating
  • SeshSesh Frets: 1847
    Nobody mention the other secret areas though. Shhh.
    Can't sing, can't dance, can handle a guitar a little.
  • TroglodyteTroglodyte Frets: 18
    Bridgehouse said:
    Done both. It’s not a posts number - it’s a hangover from classifieds access requirements for new members. I’ve changed both so you get the standard member privileges now. If there’s any more say here and I’ll do them. It’s a 20 second fix
    I can't see it either...
    Done
  • KittyfriskKittyfrisk Frets: 18865
    I may live to regret this, but yes please.
    Done. Good luck in there...
    Thanks, I should possibly have re-read the Pandora story, or the one about the curious cat first...
  • FunkfingersFunkfingers Frets: 14496
    Even if/when you finally gain admission to BCD, if you have the right two or three forumites on your Ignore List, almost all of the content will be greyed out. ;)
    Interesting fact - as a modmin I can’t ignore anyone’s content as I need to be able to read it all.
    Gah
    Good advice.
    Hope not to need to 'ignore list' anyone  ;)
