No problem. I'll have a go. So you want it with just dry and octave down about the same level?
I suspose if I'm going to do this I should also show the dry plus octave up, and octave down plus dry plus octave up.
i can vouch for the micro pog too. Was surprised how good it is. Sold the Hog when i realised i only really used it for Poglike octaving
I'm not sure I have similar settings, I have them set to do the same job. the sd1 clone seems to have a bit less boost with the gain at minimum so I have the gain on it at maybe 8 o'clock whereas the gain is at minimum on the BM.
I still reckon the BM is smoother but I'll have to try them again to see )
Cheers for the heads up. If you get one let me know how you get on. That or a velvet has got me very tempted. I will, but you know what I'm like at making a decision on anything.
Just buy one and sell it to me if you don't like it Some of the demos are great, Pete Thorn's and Prymaxe Vintage sound great but I swear I can get close to some of it's tones with the VFE Scream(TS type) going into the Blue Bogner. It must have a lot of versatility though. It seems like a Fuzz/Fuzzy O.D pedal, but then again, the more tones the merrier. I have heard some of the sounds I've had in mind from it, so it looks on the cards.
