Have a nemesis arriving tomorrow, so will have a view on that soon, but from what I've seen it looks decent.
Can't image anything topping a Volante for tape delay though.... unless you go with an actual tape unit, which isn't very pedalboard friendly.
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
But if you have an fx loop, consider a lexicon mx 200 - super simple, great delays and perfect reverbs too and you can footswitch it on an off with a basic switch pedal.
I still feel like the Nemesis could be a little better in that I have to use an external tap switch for change presets by foot. I would prefer if the tap tempo button could be re-assigned to do it. Seems like this is an area where the Boss DD-200 Has an advantage?
Overall I am very happy with the Nemesis but still feel like I could do with an idiot proof, easy to see in the dark foot switchable preset pedal that sounds amazing and comes in a small package!
Someone told me there's such a thing as a 'manual' for pedals. I know, I've never read one either. Nevertheless, it does seem to be quite useful.
Nemesis manual:
Preset Storage and Recall
The Nemesis features 128 user presets. User Presets store all user editable parameters. This includes the knob positions, current effect engine, the full list of Neuro/MIDI accessible parameters, and the current settings for external control. After a preset is recalled, you can always tweak it in a performance situation by turning a knob. The knob parameter will then “jump” to the knob position once the knob is moved.
Recalling Presets
By default, 4 of the 128 presets are accessible via the hardware. Presets can be recalled via hardware in three ways:
- Press the SELECT button to cycle through the hardware user presets.
- When the effect is bypassed, you can press and hold the TAP footswitch to perform the same function as the SELECT button to cycle through the presets.
- Connect an external footswitch to the PEDAL IN jack and use SWITCH mode to step through presets. 1 2 3 4 5 6 7 8 SA260 Nemesis Delay User’s Guide 24
An additional 4 user hardware presets are accessible in Preset Extension Mode. In this mode, the number of presets available on the hardware interface is increased to a total of 8. The Preset SELECT button will now increment through 8 presets instead of 4. The second bank of four is indicated by the ON/OFF LED being lit red.
The remaining 120 presets are accessible by sending a MIDI Program Change messages from an external controller to the MIDI input (you can also access the first 8 presets via MIDI if you wish). Each User Preset is hard mapped to its respective MIDI PC number. For example, MIDI PC 1 will recall User Preset 1 and so on up to PC 128/User Preset 128.
Otherwise if you like darker repeats, the carbon copy never gets old.
I did know about holding the tap tempo, but I am paranoid that it’s not quick enough for changing Presets in a live setting, so for now the external tap switch is better.
However I also use the Source Audio Vertigo and True Spring, so a Neuro Hub may be on the cards!
