How many guitars,amps and pedals?
  • last count 32 guitars, 1 amp and countless pedals !!!
  • sixwheeltyrrelsixwheeltyrrel Frets: 186
    edited September 2020
    2 electrics
    1 amp
    6 pedals
    I know, I must try harder :-)
    Actually I do (or rather did) own a third guitar but my son has that on loan forever.
  • bodhibodhi Frets: 1334
    2 electrics
    1 acoustic incoming
    1 amp
    4 pedals
  • RockerRocker Frets: 5003
    6 Electrics
    1 Acoustic
    1 Bass
    1 Slide guitar
    1 Yamaha keyboard
    3 Bass amps
    1 Keyboard amp
    4 Guitar amps
    1 Pod V2
    3 Pedals
    3 Tuners
    And approaching the age when I should know better.
    Nil Satis Nisi Optimum
  • RolandRoland Frets: 8792
    4 electrics bought, and gathering dust.
    A growing number of homemade electrics, and more on the way.
    1 bass
    3 acoustics
    1 amp and 1 FRFR powered speaker
    4 pedals, TS-9 and CryBaby used for reference, LS-2 and TS-2 on shelf.
    2 AxeFX
    Enough gear for two PAs
  • Alex2678Alex2678 Frets: 1159
    1 electric
    1 acoustic
    1 amp
    7 pedals on the board, 2 in a drawer
  • 11 electrics
    3 acoustics
    4 amps
    14 pedals on my board (and about the same in their boxes)
    Several of the above passed to my son to avoid selling them. :-)
  • octatonicoctatonic Frets: 33858
    About 25 guitars/basses, 8 amps, 200-ish pedals.
  • enjoenjo Frets: 278
    4 Electric guitars (LP, Strat, Tele, Semi)
    1 Acoustic guitar
    1 Bass guitar
    1 Guitalele
    1 Ukulele
    1 Guitar Amp
    1 Bass Amp
    8 Pedals
    I think I've found my happy place.
  • DavusPGDavusPG Frets: 451
    10 Electrics
    1 Bass
    1 AxeFX3
    Fractal FC6
    Fractal FC12 (Probably going)
    2 Expression Pedals
    1 Redsound Rack Cab
    Then I still have the items below, but they've been gathering dust since I switched to Fractal a few years back, figured I'd keep them as I'll inevitably want to go back to a traditional set up at some point - the grass is always greener!
    H&K Grandmeister 36
    Zilla 1x12
    H&K 2x12
  • TTBZTTBZ Frets: 2919
    TTBZ said:
    ...my strat copy is so awful it's almost not worth counting.
    *That* bad???
    It's actually alright to play now I've lowered the action a bit so I retract that. The frets on it are tiny so it's never gonna be great for my tastes. Sounds totally dead unplugged but it's ok plugged in. Might rebuild it part by part into something worthwhile :)
  • DaevidJDaevidJ Frets: 414
    3 x Electric Guitars
    1 x Bass
    1 x Bass/ Electric Guitar (VI)
    1 x Electro Acoustic
    2 x Amps
    11 x Effects Pedals (8 in use)
  • 2 Electrics
     2 Acoustics
     1 Ukulele
     1 Cigar Box Guitar
     3 Amps - Blues Deuxe, Laney Cub 10, Yamaha THR10C
     15ish pedals
  • steersteer Frets: 1204
    5 Electrics
    1 Resonator
    1 Acoustic
    2 amps (plus one out on loan)
    about 12 pedals (only 8 of which live on the pedal board)
  • mbembe Frets: 1840
    17 electric guitars
    9 practice amps
    1 bass guitar
    1 dozen pedals
    2 analog drum machines
    5 analog synths
    2 mobility scooters
  • 2 acoustics
    2 ukuleles
    1 bass
    3.5 electrics
    1 cab
    1 power amp
    5 pedals (soon to be 1 or 2)
    6 electrics
    2 amps
    1 nylon string acoustic
    about a dozen pedals
    1 x multi fx unit.
  • ICBM said:
    Fuengi said:
    Why 3 acoustics? I'm finding two is possibly one too many.
    One 12-string, one good 6-string, one cheap 6-string with a magnetic pickup in it for open mics, acoustic sounds with distortion etc.
    Also not counting the travel-size one which is technically mine but seems to belong to my daughter now... :)
    also different tunings
    different nut size
    and.. if you are fussy, some have different resonance: Lowden/Avalon guitars are amazing but add lots of overtones. Some complicated pieces can work better with less overtones, with a more traditional USA-style bracing pattern
    Diff woods work better with styles too. Adirondack + Rosewood is best for pick playing and strumming for me, but cedar or redwood for fingerstyle
  • I’d best not go there...
    I'm probably in the same boat. Must have been something in the air, or the water at Stubber's Green
  • mbe said:
    17 electric guitars
    9 practice amps
    1 bass guitar
    1 dozen pedals
    5 analog synths
    2 mobility scooters
    does your playing improve faster if you use 2 or 3 practice amps at the same time?
