Here's one. 0dB/watt. Very inefficient.
Bandcamp
Spotify, Apple et al
92.5 - 99.5 dB variable sensitivity
Yes, as Dave says the Rocket 50 (G12E-50) is only 95dB, but that won't actually reduce the volume that much, and they sound sh......
The Jensen P12R at just under 94dB (the lowest I can think of for any 12" guitar speaker) might be a better bet since they do actually sound good, but to get any serious volume reduction an attenuator will still be more effective.
Eminence make a couple of speakers with built-in attenuation via a large knob on the back - the Maverick and Reignmaker - which I think work by winding the magnet out of the coil - but they're fairly expensive and still not as quiet as an actual attenuator.
I had some in a very similar amp and at home they were quite nice.
I’d avoid the Reignmaker. I had one of those too and it was ok with clean sounds but sounded terrible with any distortion.
An attenuator was far far better.
G12L 15w from the 60s is very quiet.
