Mesa Boogie Five-Band Graphic
HootsmonHootsmon Frets: 15976
Just askin' folks....what makes this particular EQ pedal so expensive at almost 300 quid?
Does it offer up anything more than the MXR/ Dunlops for example?
tae be or not tae be
  • prlgmnrprlgmnr Frets: 3991
    Hootsmon said:
    Mesa Boogie
  • ICBMICBM Frets: 72446
    Says the man with overdrive pedals which cost more than some amps ;).
    Answer - because it sounds exactly like the ones in their amps, and they can...
    They do have different frequency centres from other EQs, if that matters. They're also remarkably nice-sounding - the EQ circuit is actually used in a couple of Mesa amps, as a sealed unit with no controls, purely to make the amp sound better. They call it the 'Mojo Module', but really it's just the same four-transistor circuit with no sliders.
    Transistors make a valve amp sound better? Yes :).
    1reaction image LOL 1reaction image Wow! 1reaction image Wisdom
  • SassafrasSassafras Frets: 30294
    None of their pedals are what you'd call bargains.
    Sassafras said:
    None of their products are what you'd call bargains.
    FTFY :)
    Although it is fair to say the amps do usually have feature sets which aren't often found all at the same time on other amps, and are well-made, so they justify their prices in that sense.
  • Sassafras said:
    None IS
    FTFY.
    None - contraction of “not one”. Singular.
    It seems to on my old Quad Pre-Amp rack.
    The chosen frequency values all seem to do something useful without ruining the guitar tone through overzealous narrow band boosting or cutting.
    I suspect that this module plus a pot explains the Notch control on the Throttle Box pedal.
    "None of their products IS what you'd call bargains"
    No, sorry, it just doesn't sound what you'd call right.
    No one here are going to agree with you :)
    None here is going to agree with yous.
