WezV DC Juniorish build
  • JazzthatJazzthat Frets: 163
    Looking cool . I personally like the black borders around inlays .
    I am looking forward to see what they look like once lacquered .
    What's sort of finish are you going to apply to fingerboard ?
  • WezVWezV Frets: 16793
    it will be nitro all over.  Tv Yellow on the body and a light amber tint on the neck.
    It may end up a fairly consistent colour over the whole guitar when I spray the tints. we will have to see, and tweak the colour tones if needed
    I am also considering nitro on my project guitar , well neck for now , and see how it goes later with the body .
    How do you go about polishing fretboard between frets once nitro ( or any top coat )has been applied?
    On my last spray , it was a long journey before I got reasonably good finish  , but it's far from perfect.
    This time round I am going to lightly lacquer the fretboard , polish , buff and then put frets in ( for the first time :) ) .
    Hopefully this will look good .
    I try to get a level coat right over the frets, then scrape them back fairly soon after painting.
    I don't want to be level sanding between frets, so laying a nice even coat is key.
    Oh I see . That's probably where I had gone wrong with it .
    I needed to sand between frets to get  the shine to high gloss .
  • SteveRobinsonSteveRobinson Frets: 7079
    In Dan Erlewines book on fretting he shows a technique of sanding between frets with tiny pieces of abrasive, using a circular motion.
    It's a slow process but it does work to remove orange peel and other imperfections
    We all know fender are not individually sanding between frets every time they lacquer a maple board.... the aim is to not have to sand at all.
    So far I have finished sanded, sealed , then fretted.  The sealer helps keep the board clean whilst I do the rest of the work, and should help ensure I am fully prepped for an easy finish later in the process.
    I'm more worried about getting the TV yellow right than I am finishing a maple neck :D
    Well yes, this is how I approach a maple neck too. A single coat of clear lacquer is enough to seal.
    But sometimes you do need to sand between frets!
    Yeah I've seen that initial coat on maple fretboard approach on your website :)
    I now think , I'll stick to finish after frets .
    I am looking forward to see end results on that build .
    Can you post close ups of finish between frets once you have done that ?
    I'd like to see how you do it without polishing  as I have failed miserably on that :)
    edited December 2020
    There is a maple boarded build of mine that's already lacquered a few threads down from this one
    Also, I didn't say no polishing.... I said no level sanding
    And I should point out my aim is usually "vintage patina" rather than high gloss
    Yeah my bad , I meant level sanding :)
    edited February 2021
    The weather has been delaying the start of finishing, but today seems like a good day to start.    Just sprayed the first dusting of white basecoat
  • PhilKingPhilKing Frets: 1495
    Great to see this coming back onto the radar Wez
    A few months settling in with strings on will have helped  ensure its all nice and stable, and it allowed me to get the worst of the weather out the way
    Its now had a couple of coats of white.  This will be followed by some natural wood coloured grainfiller before the yellow starts.
    One concern is the possibility both neck and body will end up too similar in colour, as both will rely on amber tints.   To try and control this a bit I am going to do the body colour first, then spray the neck separately with its own tint.  Something with less yellow, and a slight hint of tobacco brown perhaps.
    Put the first coat of  tint on the body.  Its more of an early 50's wheat than a late 50's yellow... but 2 more coats should warm it up and let me see if I need to use a more obviously yellow colour.
    This is 3 coats of lightly tinted nitro.  Definitely getting there, but maybe still a bit pale at the moment ???
    I don't think it's too pale at all. I'd stop there.
    I find it's always risky to think "just one more coat" and it tips you over the edge and there's no going back.
    Yeah, that's why I decided to stop and think about it.  I can always add more, but can't really start again on this type of finish without losing the grain.
