Hi all,
I am just about to retire which means that I am going to have more time to play and also some spare cash. I've played on and off over the years but never really beyond the strum a few chords and play a few riffs stage. Now I want to change that. I'm mainly interested in playing blues and some classic rock. Over the years I've accumulated several guitars (US Strat, Squire Tele, Epi LP etc) all of which I'm pretty happy with. What I've never had is a decent amp, they've always been relatively cheap practice ones, nothing above £150. So I've decided that as a retirement present to myself I'm going to lash out on an amp, up to about £750. It will be used mostly at home but I would like, once I get a bit of confidence/skill, to be able to go to open mike/jam sessions.
So I started looking......and went down the rabbit hole of looking at amps on the web.
I sort of started off by thinking about a Blues Junior, then found out about modded BJs and then found the whole amp kit world (I was an electronics engineer in a previous life, so building my own does appeal). Then I read that valve amps are a no-no at home volumes and what I should be looking at is something like the Yamaha THR.
So advice, please. Can I have a 'proper' amp at home? Can I kit build one? Do I have to have something that looks like a sound bar for a tv?
Totally dazed & confused
Lee
If you're going to have to have the volume right down all the time though it's maybe not worth it. Some valve amps need to be pretty loud to get any kind of distortion. I use pedals with mine.
Plus modern ss practice amps can have all sorts of voices and features that most small valve amps won't have.
Contrary to "popular wisdom" the power of the amp doesn't matter - only how effectively you can control it. You can easily have a 100W amp which sounds fine at whisper volume if it has a master volume control that works well. (Or conversely, a 5W amp that's too loud because it doesn't.) Multiple volume controls in series helps - ie a channel volume *and* an overall master volume or 'output level' control, since you can turn both down.
If that doesn't give you the type of sound and control you want, any amp that has a detachable speaker connection can be attenuated.
Speaker sensitivity also matters, and a low-sensitivity 10" speaker will give a much lower volume than a high-sensitivity 12", even with the same amp power - and may well have less of the bottom-end which can cause volume problems at home. I wouldn't go smaller than 10", most 8"s don't sound great unless you want a specific 'vintage small blues amp' type sound, and there aren't as many good choices either.
All that said, I would probably stick to the 5W-15W range for a valve amp as that will give you enough power to be heard in public if that time comes, but is still going to be small and light enough not to take up too much room at home and carry around easily - or maybe 30-75W for solid-state, they don't sound as loud as valve amps for the same rated power (for several genuine reasons, not because they're no good).
Hope that helps, and welcome to the rabbit hole .
They are a genuinely much better amp - although substantially bigger and heavier. You can use the 'other kind of attenuator' with them too - a signal-level one that goes in the FX loop, like the much-loved Dr. Watson Lion Tamer .
Some valve amps have absolutely glorious clean sounds and make for excellent pedal platforms.
What I do use at home now, and for jamming when/if it’s possible again - is a Princeton 65 reissue. Absolutely sublime clean sounds, tremolo and reverb. Sounds great with pedals and awesome when you can turn it up to growl (which is way too loud for home at that point - don’t let the 10 inch speaker fool you. I saw a small pub blues gig back in 2019 with two guitarists playing, one of whom had a Princeton and it was keeping up easily - he was having to use a pedal to get enough crunch for lead with a strat).
Edit: how about building your own drive pedals? Must be tons of Tubescreamer and Rat kits out there for instance.
My experience is probably unique which is why i suggested that the op try some amps. Just because people here like said amps it doesn't follow that the op will
https://www.thefretboard.co.uk/discussion/201608/tone-king-falcon-grande-turquoise#latest
