WezV DC Juniorish build
  • WezVWezV Frets: 16816
    I'm also aware it would look a lot more yellow next to a rosewood board
  • davrosdavros Frets: 1362
    It's difficult to know how the photo compares with real life, but I'd say that looks about right.
  • PhilKingPhilKing Frets: 1496
    I think the colour looks great Wez.  I like how it's coming together.
    The second pic is in more direct sunlight, and I think that pushes it towards the yellower end of vintage white.
    But it is easy to overthink these things
  • SteveRobinsonSteveRobinson Frets: 7090
    I like the colour in the middle picture best.
  • Ooooh....this is looking VERY nice :)
  • PeteCPeteC Frets: 409
    This look great with the Yellow finish and the maple neck and "birchy" inlays.
    Any more pics yet ?
    edited March 2021
    Nah,its been cleared and is hanging out to cure
    I did add a slight tobacco tint to the neck, but other than that it looks as it did above
    Hi Wez, will the headstock face be black?
    I have left natural so far.... but was debating it.   What would you prefer?
    I think I'd like it black, just as a visual contrast and sort of a defining look.  Also, though they are not fitted yet, if the pole pieces on the middle pickup can be closer to the fingerboard, I think that would be better too.  Not that I really know how it would affect the sound!
    this is now buffed out and has had a bit of ageing added to match the older bits of hardware.  Just done a test fit to see what i still need to do.
    I need to do a bit more work finessing the plate bevel, but its not too far off done now.
    hard to capture the colour though
    we have light grainfill + sunken grain to try and get an aged appearance.. plus a few chips, and some checking on the go, this one wanted to follow the grain
    the neck is less aged other than a tint and light checking... makes sense if you think of it as a 50's body with 70's neck replacement.
    looks paler in this light, but shows headstock is now black.  wasn't sure about this, but I now think it works well for some contrast
    And now for a proper faceplate moment.
    Just come to do the fretwork and there is a very obvious bump at the 13th fret... I assume a fret must have popped.
    Nope.   I somehow switched wire at the 13th fret  to a bigger size.   Sometimes nice when frets get smaller up the top end, but this is less than ideal.
    Therefore the next job will be to replace frets 13-22.  The boards still level so I shouldn't need to redo it all.
    I can only assume my fretwire got mixed up when I cleared out the old workshop a couple of years ago.
    This may be the silliest mistake I have made for a while.  At least it wasn't a popped fret, as that would make me question the rest
    It is really looking great Wez.  The colour looks awesome and I like how the neck is.
    Looks fantastic, just like something Birch has got his hands on!
    The wrong frets have now been replaced.  I have some finish work to do just to touch up the fretboard a bit, but thought it best to fit some strings on and make sure everything else is fine.
    Thankfully it is.  Kubrick  approves.
    Also bevelled the guard more, but i need to get that bottom layer a bit more even yet.
    Suddenly its starting to look like a proper guitar
    Looks great and a fitting Birch tribute.  Now that the body colour is done those inlays really work very well.
    Would love to know how the pickup spacing combination sounds too.
  • JazzthatJazzthat Frets: 163
    It Looks fabulous ! I like the fretboard and colour choice going on there .
    If I may add a small criticism though , those bridge locking screws are looking out of place being so long :) .
    Great job @WezV ;
    Thats a vintage badass bridge for you.  It has a massive amount of intonation adjustment, most of which won't be needed
    Never seen one like it :)
