"Anybody can play. The note is only 20%. The attitude of the motherf*cker who plays it is 80%" - Miles Davis
Which pedals? The internet wisdom is to keep analogue and digital pedals isolated from each other, and in general analogue pedals draw less current than digital ones do, so it's probably easiest to put several analogue pedals on the same output.
The drives are Origin Effects (RevivalTrem and Magma) - not sure how heavy they are on the draw.
It's generally the rule of thumb but each set up is different and you can only tell 100% when actually trying it.
Origin website reckons 100mA each (and they should know...), so in theory you could run both from a single 500mA output on your Zuma with no problems.
Thanks folks.
Any analogue pedals will be super low current draw with the exception of those with digital features - some analogue delays, programmable drives etc. Any standard analogue pedals will be fine I reckon.
Ebay mark7777_1
I bought two and both suddenly stopped working?! Tried with two Zumas and a bunch of pedal (all well under 500mA combined). Really odd. Worked for two weeks, now don’t.
